SR Light Bar Installed -- Grille/Bumper Gap - 2014+ Jeep Cherokee Forums
 27Likes
post #1 of 37 (permalink) Old 10-27-2016, 11:51 AM Thread Starter
Hey guys just completed my hidden single row light bar install. After searching the forums I haven't found anyone with the hood/bumper gap set up..So here's my write up!
2015 Cherokee Trailhawk (without adaptive cruise control -->acc may interfere with light mounting)
Light bar - Rigid Industries SR2 10" Driving/Hyperspot Combo Pattern
After buying the Cherokee a year ago, I was quick to discover the poor light output it produced especially with high beams..It is annoying that jeep would go and develop these awesome looking projector headlights and then stick budget halogen bulbs in them!! But that's another thread lol
I realized I was going to have to run a set of driving lights, but mounting and location was going to be an issue. I run Rigid D2's Driving pattern and Rigid Dually Spots on my other vehicle a 2012 F150. Familiar with the output of the D2's and Dually's, I knew I wasn't going to be able to run them at their full potential behind the lower grille insert on the Cherokee, as I like to run my lights hidden. After many measurements I decided to settle on a Rigid SR2 bar that would rest under the hood but project its light cleanly through the hood/bumper gap. Mounting a bracket to the bumper hidden under the plastic covering seemed to be a head scratcher, until I pried back the top part of the plastic covering the bumper to expose the top/inner metal of the bumper. While pried back, there was just enough room to run a drill bit down through the metal resulting in 0 damage to the plastic. With these 2 holes drilled I could now bolt my flat brackets to the flat underside of the metal bumper, which my light bar would mount to. The bolts fit snugly just before the curved lip of the bumper but hidden under the plastic trim. Mocking up the light bar on the brackets, I was left with a gap of 3" from the rad to the backside of the bar with the front of the bar flush with the plastic bumper. This position was perfect as it cleared both the hood when closed and the hood release latch, which I was was worried about. To archive the proper height of the bar I just used the taller mount brackets that came with the bar and drilled holes in them to my desired height and set in place as it is mounted now.
I ran my wiring through the aux port within the wiring grommet to the left of the brake pedal. The complete install took approx 2 hours and was relatively simple. A single row 20" bar may fit but it would be closer to the rad due to the curve in the bumper for mounting as why I went with a 10"..but I could be wrong.
After aiming the bar at night, the light output is amazing, Rigid's optics really focuses the light where it needs to be. The hood and bumper do not block any light casting noticeable. Driving I can light up street signs 1.1km down the road, with the sides of the road still flooded with light. This bar at 45 watts, 4500 lumens certainly gives my D2/Dually Spot set up = 105 watts a run for their money. This bar just slightly lacks the wide spread compared to the D2s..but heck it's got the best of both worlds in a small package at 45 watts!!
This Rigid SR2 bar is the third product I have purchased from Rigid and I must say their products are worth every penny. My D2/Dually set up on my truck has been on for 4 years now and still bright as new with high usage. Highly recommend their products for the extra couple bucks!
Here's some pics of the install and light output. The pics of the bar are shown aimed high, as the pics were prior to aiming.
Enjoy!
ID:	140073   Click image for larger version
ID:	140081   Click image for larger version
ID:	140089   Click image for larger version
ID:	140097   Click image for larger version
ID:	140113   Click image for larger version
med-hawk is offline
post #2 of 37 (permalink) Old 10-27-2016, 01:08 PM
Looks awesome, great stuff man
evilhomer is offline
post #3 of 37 (permalink) Old 10-27-2016, 01:20 PM
I am a frequent customer of rigid lights lol.
post #4 of 37 (permalink) Old 10-27-2016, 01:23 PM
Also, you can swap out the fog lights for the rigid fog lights but you'll need the JK fog light adaptor. Single greatest upgrade I've done on my Cherokee. And I've done a lot of them.
post #5 of 37 (permalink) Old 10-27-2016, 02:32 PM
raymorr's Avatar
That's looks good I think I will also make my one like that coz I'm always worried if the rigid light will get stolen I put mine on the top of my plate number you never remove the front bumper right? ..
2015 Cherokee North AD II
Granite Crystal Metallic
Safety Tech , Cold Weather, Convenience, Sunroof,Nav
Thule Canyon Basket, Thule AeroBlade
245/65/17
raymorr is online now
post #6 of 37 (permalink) Old 10-27-2016, 04:07 PM Thread Starter
No bumper removal. I just pulled up and back on the plastic and held it back as I drilled.
raymorr likes this.
med-hawk is offline
post #7 of 37 (permalink) Old 10-27-2016, 04:42 PM
john.thwaite's Avatar
Looks great! How did you mount the horizontal bracket that the light's mounting bracket bolts into? You'd want it nice and rigid to minimise vibration, right?
And I do have ACC on mine - but I don't think there's much "stuff" above the bumber bar line that would get in the way.
john.thwaite is offline
post #8 of 37 (permalink) Old 10-27-2016, 04:49 PM Thread Starter
It's mounted to the flat underside of the inner metal bumper. With the bar mounted it's pretty solid with no vibrations. So far so good lol
raymorr likes this.
med-hawk is offline
post #9 of 37 (permalink) Old 10-29-2016, 12:25 AM
JAhmed's Avatar
Looks great OP, very stealth!
2017 Jeep Grand Cherokee Trailhawk - [HEMI/NAV] All Weather Animal
2016 Porsche Cayman GTS - [6MT/X73/PTV] Track/Touge Scalpel
JAhmed is offline
post #10 of 37 (permalink) Old 10-29-2016, 03:53 AM
kylepezz's Avatar
Did the 2015 year have a bigger gap between the bumper and the hood? I'm getting a 2016 Latitude and the gap doesn't seem as big. I actually work next to a car dealer so I went to go look and I'm trying to eyeball this post with the car in the lot and it doesn't seem as big.
I definitely want to do this though because I'll be driving in rural NC.
kylepezz is offline
Hidden light bar in grille? Hawkee Exterior 8 10-30-2016 09:50 AM
Installed 32" light bar Tarasisko 2014+ Jeep Cherokee General Discussion 19 05-31-2016 09:06 AM
Bumper light bar installation help ArcticLyn Owners' Garage 14 03-01-2016 09:47 PM
Theoretically asking, can a bumper mounted light bar wisconsinwalter Electronics, Audio, and Lighting 11 01-02-2016 01:19 AM
Front bumper light bar bracket David_Baker Electronics, Audio, and Lighting 13 09-17-2015 01:19 AM
