Exterior damage - Page 2 - 2014+ Jeep Cherokee Forums
 7Likes
post #11 of 11 (permalink) Old 01-11-2017, 09:17 AM
Exterior damage
Hi, all the hoods are the same with exception to trim. So if your grill inserts are not damaged you can transfer those, along with the heat shield and windshield washers. Otherwise you will have to also purchase all of those too. Unless you get a hood off a Cherokee in a wrecking yard you will also likely need to have it painted as they often come only in primer and ready for paint.
As for the DRL a quick google search revealed several places you can likely purchase them. Though again, I'd try a wrecking yard.
Edit: I forgot, you'll likely need a new rubber gasket as well. My hood was damaged a few months ago and I was told it would be nearly 900$ with everything painted for a new one.
https://www.google.com/search?q=cher...&bih=628&dpr=3
Battle Damage...who's got it? Jenk Off-Road 14 01-18-2017 10:10 PM
So what happens if you damage a loaner? :O shemmar360 The JCC Lounge 10 12-26-2016 09:26 AM
Storm damage Hudsonhawk The JCC Lounge 15 04-09-2016 09:06 PM
Hail Damage sjones0812 Exterior 7 08-05-2015 01:31 AM
Hail Damage!!!! rebecca89 Owners' Garage 18 08-18-2014 07:12 PM
