Guess you could say I was running on fumes? - 2014+ Jeep Cherokee Forums
 9Likes
post #1 of 13 (permalink) Old 02-15-2017, 11:09 AM Thread Starter
That's where it stopped the pump the first time😅
Mark_, Duke2015 and Fj4080 like this.
Mileage: 27k+, Bought @ 18K in 2016
Status: Running perfectly
Upgrades:
* Uconnect 8.4 RA4 w/ Nav
* Interior LED foot well lights
shemmar360 is offline
post #2 of 13 (permalink) Old 02-15-2017, 11:13 AM
BurtonRW's Avatar
I'd report that. Here's a link for you:
http://www.co.dutchess.ny.us/CountyG...CH/CFindex.htm
-Rob
Fj4080 and shemmar360 like this.
BurtonRW is offline
post #3 of 13 (permalink) Old 02-15-2017, 06:00 PM
Yep, sounds like that station is ripping drivers off. Charging them for more fuel than they actually pumped into their tank.
mowcowbell is offline
post #4 of 13 (permalink) Old 02-15-2017, 07:53 PM
Special extended range tank?
'16 TH - Bone stock
red_ is offline
post #5 of 13 (permalink) Old 02-15-2017, 07:59 PM Thread Starter
Originally Posted by Duke2015 View Post
I thought the KL gas tank only holds 15.5 gallons
15.8 is what the spec sheets says I believe.
Upgrades:
post #6 of 13 (permalink) Old 02-15-2017, 08:05 PM
15.8 gallons for 2.4 and 3.2, unless it has the ballooning filler tube option .
post #7 of 13 (permalink) Old 02-15-2017, 08:14 PM
16 gallons and change very likely, if you top it off. I don't think posted capacity takes filler tube into consideration.
Warning : these Cherokees do not like topping off. Stop after the first click, don't even think about squeezing that handle again
Array, firedude and Dark like this.
post #8 of 13 (permalink) Old 02-15-2017, 08:17 PM Thread Starter
16 gallons very likely, if you top it off. I don't think posted capacity takes filler tube into consideration.
Oh trust me I know lol, I didn't top it off at all. That's where it shut off the first time.
Side note: filled up my co-workers Dodge avenger today and the pump shut it off at less than quarter of a gallon even though the tank was almost empty lol. He said he's had the problem for a while now.
Upgrades:
post #9 of 13 (permalink) Old 02-15-2017, 08:36 PM
Oh... no topping off... I don't remember anybody else putting so much in a Cherokee then. Might be worth reporting them, as suggested above.
Either the Avenger has a back pressure problem, or the nozzle needs maintenance.
post #10 of 13 (permalink) Old 02-16-2017, 07:57 AM
Actually if you did a slow fill you might have put a bit into the filler tube which would have accounted for that 15.9.
A fast fill should have shut off faster with less gas in due to the back pressure from that fast fill.
But just remember that the fuel pump requires ample gas around it to keep it cool. You do not want to continually overheat the pump as they are very expensive to replace.
But you were on fumes and you are lucky.
Thanks for the story
Fumes that are making me sick michele7312 Interior 67 11-08-2016 10:33 AM
fumes in cab - any ideas please??? uncle101 2014+ Jeep Cherokee General Discussion 11 06-05-2015 01:48 AM
Guess the make of the vehicle... cdnblkhwk 2014+ Jeep Cherokee General Discussion 7 02-20-2015 12:38 PM
Guess I'm next... Treaty Engine and Technical Discussion 45 11-04-2014 07:29 PM
Guess they didn't test the KL!? zzjdzz The Car Lounge 6 04-08-2014 03:29 PM
