Thinking About a XT17 - 2014+ Jeep Cherokee Forums
 11Likes
post #1 of 14 (permalink) Old 02-18-2017, 10:32 PM Thread Starter
Mudman1's Avatar
Hello,
I went to the RRO Site and for $1,500 I can have the bumper and winch delivered. That is a bit more than I have, and listening to folks who off-road a lot more than me, sliders are a better first investment. I hope to buy them next month or early April. I thinking about all my time in the woods, and what I use my trailer for, having a small winch would be nice. I had a Warn PowerPlant HD on my Cummins...and only used the air compressor. Never once did I need the winch. It was sort of disappointing.
I am hoping to go up to the Iron Range and down to IL this summer, for two different off-road trips. Having an extra "hand" may come in handy, I think. In looking around, I considered a hitch mounted winch. But then I am restricted to the back. And, I cannot use it to load heavy stuff into my trailer. I can't find too much info on the Warn XT17, but I think it might do the trick. Pull tree logs away, pull loads into my trailer, and give my Jeep a little boost when needed. Obviously, if I am at a Mire 1 or deeper, it won't help me much. But, if I need a nudge to get off of some rocks or am at risk of tipping, it would help. It can also be used in front or back.
Thoughts? https://www.warn.com/adventuretouring/XT17_winch.jsp
Mudman1 is offline
post #2 of 14 (permalink) Old 02-18-2017, 10:44 PM
8.5 lbs and riggable inline between load and any fixed object...$450
Kind of expensive until you need it, then it is a great piece of hardware!
Seems like a nice rig to have aboard when out on your own in a semi-rugged environment. And, as you say it can help in situations in daily life as well since it's so portable.
Mudman1 likes this.
post #3 of 14 (permalink) Old 02-18-2017, 11:00 PM Thread Starter
Mudman1's Avatar
https://www.superwinch.com/collectio...winch-winch2go
I was using The Google and came across this. It has a lot more weight capacity. The price is not too bad either. https://superwinchcompanystore.com/c...c-rope-1140232
Mudman1 is offline
post #4 of 14 (permalink) Old 02-21-2017, 08:57 PM
9Mike2's Avatar
This is for a 4500 lbs vehicle? You will over heat (the winch)and have electrical problems and may burn down your Jeep.. Be real careful use that small of a winch...the SuperWinch would be much more what you need, just remember to use good equipment, Straps and Pulleys and D rings, also with a good pulley(snatch block) you can double your line pull by coming back the the vehicle...
Overland Bound Member # 2706
2017 TrailHawk White
2015 Wrangler, Anvil, Modded
9Mike2 is offline
post #5 of 14 (permalink) Old 02-22-2017, 12:21 AM
Hey I hope you take my advice seriously when I say don't go cheap on the one item you are literally going to depend on to get you out.
In addition, you need 1.5x the weight of the vehicle for a winch. So, at 4000lbs (factory weight) you need at least a 6k winch. The vr8000 would do you just fine if you need to save money. Take it from someone who winches all the time.
In my case I weigh almost 6000lbs so I'd ideally need a 9k winch. But I can make do with an 8k and a few snatch blocks and just do a double or even triple line pull.
This is video of me trying to recover a Hyundai SantaFe. Weighs in at roughly 3500lbs. But was caked up to the doors in mud. This was with the warn m8000 and I didn't have enough power to winch him out without killing the battery in a matter of seconds.
https://youtu.be/H0z6GezfWpE
9Mike2 likes this.
Len1304 is online now
post #6 of 14 (permalink) Old 02-22-2017, 02:22 AM
9Mike2's Avatar
Listen to Len1304, I actually went with a 12,000 winch on my Wrangler for the reasons above....
Mudman1 likes this.
9Mike2 is offline
post #7 of 14 (permalink) Old 02-22-2017, 04:18 AM Thread Starter
Mudman1's Avatar
@Len1304 & @9Mike2, thank you both for your opinions and time. I agree. On my 2500 Cummins, I had the Warn PowerPlantHD for these reasons. I never once unspoolled the winch. If I were to go with the smaller XT17, it would be for loading my trailer and very LIGHT nudging of my Jeep. It would not be for a Mire Factor of one or more. The Army actually sent me through recovery school. I don't remember all the math...that was many years ago. I try to "like" the looks of the RRO setup, and try to ignore the constant complaints of their sub-par quality control. But as far as I know, they are the only ones with an option. Also, $1,600 is more than I want to spend. I agree, the SuperWinch box deal would have more power for my needs, and that might be the avenue I pursue.
Ideally, I would love to bolt on an aluminum front bumper with a heavy winch, like I did on my Ram. A BuckStop bumper. But, that is not an option. It is sad, the newer Renegade has more options. Likely because it is square, not shaped like a drill bit.
Mudman1 is offline
post #8 of 14 (permalink) Old 02-22-2017, 10:07 AM
@Mudman1 I've got a veteran owned and ran company near me who said they were willing to build a bumper for the Cherokee. But since price was up in the air I wasn't willing to dive in. Full bumper replacement with winch mount. Trendsetters I think is what they were called.
Mudman1, Xinarin13 and 9Mike2 like this.
post #9 of 14 (permalink) Old 02-22-2017, 08:13 PM
Wolfdog's Avatar
Get the rock rails and go out and have fun! Meanwhile save up for a real winch with real pulling power as suggested above, worth it!
Go Jeep!!!
Len1304, Mudman1 and 9Mike2 like this.
Wolfdog
FJR 1300 SS Tourer (me)
Wolfdog is offline
post #10 of 14 (permalink) Old 02-23-2017, 05:42 AM
Xinarin13's Avatar
@Mudman1 just get a more power puller... it's what I am considering buying.
http://www.baileysonline.com/shop.ax...2jIBoCbJTw_wcB
Not as easy to use, but it will help if you get in a tight spot... and it is for 3 tons
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is offline
Thinking of buying... Boris Kagan (hd277) Cherokee Purchasing and Orders 10 12-25-2016 07:38 AM
Thinking of Getting a 3.2 LTD josh6025 Cherokee Purchasing and Orders 26 09-07-2016 02:10 PM
Thinking about buying zeekracing 2014+ Jeep Cherokee General Discussion 17 02-10-2016 09:46 AM
Thinking of Selling the TH :( Snakeeater949 Southern California 11 07-23-2014 12:15 AM
Thinking About a Second Cherokee ups4 2014+ Jeep Cherokee General Discussion 13 06-16-2014 08:43 AM
