Spare tire and wheel question - Page 2 - 2014+ Jeep Cherokee Forums
 4Likes
post #11 of 18 (permalink) Old 02-24-2017, 08:09 PM
Originally Posted by sanghill View Post
NO. Only with the tow package it got a steel wheel with a full size Firestone tire.
Doesn't the TH come with a full size Firestone tire regardless of if you get the tow package?
fumbling is offline
post #12 of 18 (permalink) Old 02-24-2017, 09:56 PM
Seguerski's Avatar
yes.
Seguerski is offline
post #13 of 18 (permalink) Old 02-25-2017, 10:25 PM
Yes the 4wd versions get a 5th wheel with a matching spare tyre. They just neglect to inform you it's on a speed limited steel rim..
Replaced mine with another matching rim but discovered the stupid securing screw in the middle will scratch the **** out the lovely new rim.
Fix : the threaded post in the middle can be unscrewed from the floor, think it was around 4 or 5mm hex head on top.of it once the handed is removed. Turn it upside down and screw the handle on hard to lock it onto the inbuilt step on threaded bar that normally locks up against the floor mount. Reinstall wheel without damaging the spike up the middle and then insert it through the wheel and screw into the floor.
jsf721 likes this.
David_Baker is online now
post #14 of 18 (permalink) Old 02-27-2017, 04:15 PM Thread Starter
Would like to do this, I was just not 100% following the fix. Any change you can break it down 1 more time a perhaps add some pictures?
Thanks,
Jeff
jsf721 is offline
post #15 of 18 (permalink) Old 02-27-2017, 06:33 PM
Sorry I do have some pics somewhere just can't find them right now!
Basically just pull the spare out and it leaves the silver threaded bar that holds the wheel attached to the floor. The top of it has a very small bolt head of around 4mm from memory. Unscrew the the threaded bar from the floor, turn it upside down and screw the handle onto what was the bottom of the threaded bar and lock it up tight. Then you have the threaded bar in you hand with a handle on it. Put the wheel back in (now nice and easy as the threaded bar is not in the way), put the jack back in and then holding the handle place the threaded bar through the wheel and screw it into the floor.
post #16 of 18 (permalink) Old 02-27-2017, 08:16 PM
cpaulsen's Avatar
Mine came with the TH wheel and full size tire.
cpaulsen is offline
post #17 of 18 (permalink) Old 02-28-2017, 11:29 AM
Have not tried to put a stock TH wheel and tire in the spare tire well. Waiting for the answer.
Yes, they do fit. I have a 5th stock Trailhawk rim, with 245/75/17 tire on it, and it fits in the wheel well fine.
post #18 of 18 (permalink) Old 02-28-2017, 04:40 PM
Yep ditto. But make sure to make the post removable or you will scratch it
Spare tire question SBDFAN Wheels, Tires, Brakes, and Suspension 7 03-08-2016 09:47 PM
For sale - Facory TH spare tire / Steel Wheel mtudb24 Cherokee (KL) Parts & Accessories 10 01-18-2015 01:20 AM
Cargo Carrier / spare tire wheel well SD Brad Exterior 0 10-29-2014 08:58 PM
No TPMS on spare tire/wheel PCRit Wheels, Tires, Brakes, and Suspension 39 09-11-2014 03:17 PM
FOR SALE
TH full size spare tire and steel wheel
DarthBauer Cherokee (KL) Parts & Accessories 8 07-22-2014 06:02 PM
