What a PITA today! - Page 2 - 2014+ Jeep Cherokee Forums
 4Likes
post #11 of 12 (permalink) Old 06-17-2017, 05:51 PM
Originally Posted by JeffD View Post
.... One thing I am trying to figure out now is what type of switch and how to mount it for the 10 amp line from the battery. Any recommendations or pictures? Thanks.
Most any switch capable of handling 10 amps at 12 volts is a candidate. The key is to mount it in series with the 10 amp fuse. The fuse can be left in to protect the circuit while the switch is used to turn the EPS on and off.
Some determining factors on switch selection are:
- Where do you want to mount it?
- If locating the switch in the interior then it does not need to be waterproof. Some have drilled a hole in the lower dash and mounted a switch there. If you have already poked a hole in the firewall then the wires can use the same route.
- If you locate the switch in the engine compartment then it should be waterproof. If the switch already has wires attached it can be easily spliced into (and even zip tied to) the wire with the inline fuse.
- Some switches have an LED light or on/off labeling if that is desired. However it really is not essential because part of the departure checklist should be to turn the steering wheel anyway to make sure the EPS is active.
Some examples from Amazon:
https://www.amazon.com/Trail-Tech-04...eywords=switch
https://www.amazon.com/HOTSYSTEM-Air...eywords=switch
Searching Amazon selecting "Automotive Parts & Accessories" department will turn up a myriad of choices.
post #12 of 12 (permalink) Old 06-20-2017, 03:36 PM
JeffD's Avatar
Thanks for your advice on this. I stumbled on an expensive ($10) switch today that is totally sealed for marine, motorcycle and off-road. It is a simple two position toggle. I intend to mount on the left fender upper where there is a piece of metal with no apparent purpose. I have shrink tube and will solder the wires where I splice in series with the fuse (I intend to put the switch behind the fuse as that would protect against all but about 6" of wire). Can't wait to get it set up.
Array likes this.
JeffD
Eastern Washington
2016 Cherokee Trailhawk
2016 Jayco Greyhawk
JeffD is offline
Look what I got today :D R2D2 2014+ Jeep Cherokee General Discussion 55 11-09-2015 06:30 PM
Look what I got today!! Craigman TH 2014+ Jeep Cherokee General Discussion 32 08-15-2015 08:48 PM
Today TeeHawk The JCC Lounge 2 06-22-2015 09:38 AM
Today..... Easternshore Owners' Garage 4 01-18-2014 10:13 AM
What did you do To Your KL Today dawhitesTH 2014+ Jeep Cherokee General Discussion 10 01-01-2014 03:20 PM
