Jeep Cherokee KL Bumper Design - Page 7 - 2014+ Jeep Cherokee Forums
 136Likes
post #61 of 187 (permalink) Old 04-20-2017, 03:52 PM
airishfan's Avatar
I know some aluminum is as strong or stronger then some steel and the bumper already plastic so aluminum be a up grade
airishfan is offline
post #62 of 187 (permalink) Old 04-20-2017, 05:25 PM Thread Starter
Snowhawk2015's Avatar
Originally Posted by Mudman1 View Post
This sounds good. Might I suggest a smaller windshield washer bottle in place of relocation? 1.5 gallons is a lot of fluid. Also, the front weight will need to be considered. I would opt for aluminum for a multitude of reasons. Too much weight hanging off the front will alter the dynamics in a way this platform was not designed for. Ensuring a hoop is added, or optional, for deer protection could also be adventitious. Just my few thoughts.
All good ideas, keep them coming. We talked several of these points last Fall.
1. Wash fluid tank.
Idea was to go with a liter size directly above the well liner. The forward and rear fluid lines run straight up the quarter panel. The pour spout would be located just inside the engine compartment for easy access. The wiring harness for the pump and level wouldn't have far to go.
2. Design materials.
Obviously, weight is an issue otherwise FCA wouldn't have used so much aluminum and plastic. Special consideration is given to weight owning to the fact that many KL owners are not TH owners. Materials are chosen based on capability and the intended loads. Processing and fabrication costs also need to be considered. Nobody wants to pay for a $10K titanium bumper, although I've heard it said here and other sites, "you get what you pay for". So who knows. Steel is the starting point. And if it weighs a little more, then this may be a good time to upgrade to the Dobinson spring/shock design. There's always something more isn't there? ?
3. Hoop or brush bar.
The design is very clean and uncluttered, i.e. the winch is located out of sight between the bumper and radiator. This allows a small LED light bar to be installed on the bumper inside of the hoop.
4. Air Intake.
The lower, front passenger side quarter panel houses the air intake. That has to go or be relocated. I have a K&N CAI mod so it's useless to me. I have considered a snorkel for a ram air intake, but that is down the road.
Thanks again, all ideas are welcomed.
Happy trails,
Snowhawk
Sarah Fonnesbeck
sarah@expeditionone.biz
ID:	157402   Click image for larger version
Mudman1 and Duke2015 like this.
Last edited by Snowhawk2015; 04-21-2017 at 08:11 AM. Reason: Added photos of air intake
Snowhawk2015 is online now
post #63 of 187 (permalink) Old 04-21-2017, 03:55 AM Thread Starter
Photo1 shows why we need to ditch the plastic fascia and open up the front wheels to some daylight. Photo 2 shows the backside of a "dent", passenger front. I used the boiling water technique to soften the plastic then pushed it out. Removed the OE air intake (photo 3), which draws air from behind the headlight. No wonder the engine is restricted. Installed a new fender trim due to trail damage. The final result is almost "new", photo 4, until I get it on Golden Spike.
ID:	157434   Click image for larger version
9Mike2 likes this.
post #64 of 187 (permalink) Old 04-21-2017, 04:13 AM
Mudman1's Avatar
All I can say is, if I still own my Trailhawk if this comes to market, I'll only allocate resources to it if it is made of aluminum. I am not discouraging innovation. I am just suggesting certain design aspects be examined more closely.
Mudman1 is offline
post #65 of 187 (permalink) Old 04-21-2017, 09:26 AM
edge600's Avatar
Nice work! You didn't waist much time getting it all pretty again!! Oh and no more talk about golden spike please, it's making me have withdrawals lol!
Xinarin13 and 9Mike2 like this.
edge600 is online now
post #66 of 187 (permalink) Old 04-28-2017, 11:51 PM Thread Starter
You're going to die when you see the photos. A few choice ones attached.
+ Steel Bender
+ Poison Spider
+ Golden Spike
+ Where Eagles Dare
+ Gold Bar Rim
+ Strike Ravine
+ Hole in the Rock trail**
**Busted my passenger front CV joint 15 miles in. Drove it out in Sand mode (100% rear 2wheel drive) with a tow at key steep hills. Self rescue to the road, then U-haul truck and car carrier home. Warranty repair complete. Ready to go again.
P.S. Golden Crack was kind of anticlimactic like Wipe Out Hill. The waterfall on gold bar rim scared me.
Happy trails,
Snowhawk
post #67 of 187 (permalink) Old 04-28-2017, 11:57 PM Thread Starter
Follow up,
I found that even with a 39° departure angle, I still had a little tail drag. However, once I removed the plastic fascia below the tow hitch, I was descending clean.
post #68 of 187 (permalink) Old 04-29-2017, 12:21 AM
edge600's Avatar
+ Steel Bender
+ Poison Spider
+ Golden Spike
+ Where Eagles Dare
+ Gold Bar Rim
+ Strike Ravine
Happy trails,
Snowhawk
Seriously?? Golden crack was no big deal?? I remember both being pretty surprised how easy wipeout hill was... and the one that scared you is a BIG step up!
Here I am in MT and haven't even seen my jeep in two weeks...
post #69 of 187 (permalink) Old 04-29-2017, 09:24 AM
edge600's Avatar
+ Steel Bender
+ Poison Spider
+ Golden Spike
+ Where Eagles Dare
+ Gold Bar Rim
+ Strike Ravine
Happy trails,
Snowhawk
I can still hear Dave say "that didn't sound good" lol
post #70 of 187 (permalink) Old 05-06-2017, 12:57 AM Thread Starter
Follow-up.....
I swung by Exp-One today to see how the KL bumper progress is coming and maybe get a pic of their concept. Nancy said they are no further along with the bumper design than what they had at the Winter 4x4 Jamboree; however, they have been swamped by requests. (good job!) At least 17 people wanted to put deposits down. They're not taking any money until the design is done, too much schedule pressure that way.
4x4tographer and mb1k like this.
2014 Jeep Cherokee New Headlight Design Bronco B. 2014+ Jeep Cherokee General Discussion 67 04-18-2017 12:18 AM
What inspired the Jeep Cherokee Design eak 2014+ Jeep Cherokee General Discussion 1 04-06-2014 07:49 PM
Head of Jeep explains Controversial Cherokee design Hawkman 2014+ Jeep Cherokee General Discussion 7 11-28-2013 07:03 PM
Chrysler design chief Ralph Gilles defends the design as "contemporary" Aristo 2014+ Jeep Cherokee General Discussion 18 08-26-2013 06:32 PM
