2016 Owners - Request - 2014+ Jeep Cherokee Forums
 30Likes
post #1 of 23 (permalink) Old 04-15-2017, 08:00 PM Thread Starter
deevemon's Avatar
Could I ask you folks that have a 2016 Cherokee with a few thousand miles experience to share your service/maintenance experience? Excluding the normal oil, filter, wheel balancing, etc. routine stuff, what kind of problems, if any, have you experienced?
I have a 2014 with 40K miles on it. Mine is the first year of the new model, and Iíve had several issues that Iíve tried to just mark up to first year model problems. Iím curious if Chrysler has adequately addressed these things in the later models.
Here are the issues Iíve experienced:
- 2,300 miles , vibration in lower gears. Front CV joints and axles replaced but this didnít fix it. Dealer replaced the rear transmission support strut which fixed it.
- Multiple transmission flashes
- 12,059 miles, Replacement of leather on the front driverís side seat due to premature wear of the upper seat bolsters. This occurred again at 23,500 miles. Bother covered under warranty.
- 31,121 miles, Check engine light that was finally addressed by replacement of the transmission! ?
- 38,639 miles, Oil pressure sensor failure
- 39,845 miles, Replacement of the left front ball joint/steering knuckle. This was a $700+ out-of-pocket cost
So, have these issues been fixed in the later models?
Thanks,
Dave
White Limited 4x4
Vesuvius Interior
Active Drive I
V6, Tech, Lux, Tow
8.4N, CD, Charge Pad
Bld Date 6/2014
deevemon is offline
post #2 of 23 (permalink) Old 04-15-2017, 09:17 PM
Montaska's Avatar
I have a 2016 Latitude V6 with 6325 miles. I just took it in today for the first oil change.
The only issue that I've had is a loose wiper that did have a recall fix out for it but I just tightened it, myself. Otherwise, it's been great.
I also drove it about 4,000 miles from Montana to Alaska. No issues at all.
deevemon and Champagne InHand like this.
Montaska is offline
post #3 of 23 (permalink) Old 04-15-2017, 09:25 PM
chris oickle's Avatar
I have a 2016 Trailhawk I bought new in October 2015 and has an August 2015 build date, it now has 38500 kms on it, I've changed my own oil since new every 8000kms, I had it in for an alignment after installing my hazzard lift at 23000kms at which time the dealer did a thorough check over and tire rotation, they found nothing wrong and I have had absolutely zero issues with mine, couldn't be happier with it.
Sent from my SM-T350 using Tapatalk
My future plan for mods include BFG AT ko, flowmaster exhaust, and K@N cold air intake.
chris oickle is offline
post #4 of 23 (permalink) Old 04-15-2017, 10:04 PM
2016 Cherokee with 27,000 miles on it. Other than the occasional glitch it's not had to go to the dealer for anything that wasn't a quick fix.
deevemon and sgrim like this.
Len1304 is online now
post #5 of 23 (permalink) Old 04-15-2017, 10:11 PM
Champagne InHand's Avatar
I have a 2016 TH. Build date was Oct 2015. Haven't had an issue yet. I have changed my oil twice. I bought it January 2016. We have cold Winters and hot muggy Summers so I change the oil twice a year regardless.
I will be changing wiper blades some time this month, and have the cabin filter in the house, just haven't changed it. I took the TH in for a recall on the torque for the DS wiper but mine was well within specs so nothing was done to the arm but I did rotate my tires as I have that done every other oil change as well. Again no problems..., yet?
"What shall we have first?"
" an '82 Margaux"
"Is it any good?"
Champagne InHand is offline
post #6 of 23 (permalink) Old 04-15-2017, 10:27 PM
Purchased mine last August 24. I now have a little over 4,000 miles on it. Trip to the Dealer for the TSB concerning the rear seat squeaking (it was actually the driver's side roof rail rear mount being loose!) and my sunroof banging. This was fixed with some of the $200 tape used to silence the squeak in the rear seat! So, the tape was put to good use. Oil change notification has not happened; my Service Advisor suggested that I get the oil changed at 5,000 miles.
post #7 of 23 (permalink) Old 04-15-2017, 11:52 PM
Unican's Avatar
2016 Trailhawk. 38,000km and no issues yet.
2016 Trail Hawk. Deep Cherry Red. I like it!!
Unican is offline
post #8 of 23 (permalink) Old 04-16-2017, 05:01 AM
airishfan's Avatar
I have a 2016 TH that i had for a year now with 16000 miles on it and I drive to Ca from Vegas all the time and been offroading lots and had two oil changes and only thing I had was some knocking noise when i leave from a dead stop but ended up being dirt in the hub ,lol
deevemon likes this.
airishfan is offline
post #9 of 23 (permalink) Old 04-16-2017, 07:36 AM
goobnav's Avatar
2016, November 2015 build date, just over 15K miles, purchased 12/29/15, the only issue, rear axle whine that was fixed under a TSB, never affected availability.
2 oil changes, just got new wipers, filters engine and cabin but, won't be changing them till the pollen count lowers here.
goobnav is offline
post #10 of 23 (permalink) Old 04-16-2017, 11:29 AM Thread Starter
deevemon's Avatar
Thanks for all the input! Maybe the early model problems have been addressed. I love the vehicle except for the numerous dealer visits and would conside trading it in for a later model once convinced of improved quality.
Thanks again!
Champagne InHand likes this.
Dave
White Limited 4x4
Vesuvius Interior
Active Drive I
V6, Tech, Lux, Tow
Bld Date 6/2014
deevemon is offline
2016 Year Model Owners : Who has successfully installed an HID Kit with no issues ? Txmusicman7 Electronics, Audio, and Lighting 2 02-01-2016 05:01 PM
Request for Trailhawk Owners Tyler-98-W68 Wheels, Tires, Brakes, and Suspension 18 01-08-2014 07:28 PM
