Wiring Need Help. - Page 2 - 2014+ Jeep Cherokee Forums
 3Likes
post #11 of 13 (permalink) Old 04-21-2017, 11:23 PM
I'm going to be doing this very shortly with my lights, but I'll be having a little more complicated setup which will involve the addition of diodes to protect backfeed into my circuit and also to protect against backfeed into the car's sensitive electrical system. It's going to be an awesome setup when it's done, I'm just waiting on two small components to finalize my project. Then I'm going to do a complete build thread to answer any questions related to my build.
post #12 of 13 (permalink) Old 04-21-2017, 11:32 PM
Kevin@kamloops's Avatar
You need to tap a wire from the high beam wire going into the headlights , green / white
That goes back to the relay , shown in the diagram I sent you then run light bar wires and pillar lights into relay , then the pos and neg wires to the battery with an inline fuse , probably in your wiring kit , just need to fiqure which terminals on the relay you tap into,, but that's in the diagram I sent you .
Hope you get it sorted , and off road lights are legal in BC , as long as there covered up when on public roads ,
As it's spring and the CVSE are doing road checks on 4x4's around here , I've some duct tape covering my light bar , as I'm unable to find a cover for it.
Hope you get it sorted !
Kevin@kamloops is offline
post #13 of 13 (permalink) Old 04-21-2017, 11:55 PM Thread Starter
raymorr's Avatar
Wiring Need Help.
Thank you so much guys for your help .
2015 Cherokee North AD II
Granite Crystal Metallic
Safety Tech , Cold Weather, Convenience, Sunroof,Nav
Thule Canyon Basket, Thule AeroBlade
245/65/17
raymorr is offline
Wiring for LED bar on Limited with Start/Stop button NoBuzz Electronics, Audio, and Lighting 1 08-31-2016 04:04 AM
DRL LED wiring AGP Electronics, Audio, and Lighting 3 06-10-2016 10:12 PM
Rigid Industries 3" Dually LED Spot A Pillar Lights Go_Habs Electronics, Audio, and Lighting 26 03-15-2016 08:49 AM
Rigid Industries D2 led lights install thebigler Jeepcherokeeclub.com How-To's 36 11-14-2015 10:15 PM
Rigid Industries 20in E2 Combo LED Bar nathanu Electronics, Audio, and Lighting 11 05-29-2015 07:39 PM
