9th Gear on 2017 V-6's? - 2014+ Jeep Cherokee Forums
 14Likes
post #1 of 38 (permalink) Old 05-19-2017, 12:28 AM Thread Starter
Dodgeboy's Avatar
I wondered if owners of V-6, 2017 Cherokees have had any more luck hitting 9th gear than those of us with earlier years. I've found it nearly impossible to see 9th gear on my '15 Limited without doing highly illegal speeds then backing off the throttle. Since my ride has the trailer tow package with a lower axle ratio, you'd think it would hit 9th when cruising at interstate speeds, but no. I see 8th all the time but not 9th. So the purpose of a 9 speed gearbox is??
How about you 2017 owners? I know the 4-bangers see 9th frequently.
scottb likes this.
Dodgeboy is offline
post #2 of 38 (permalink) Old 05-19-2017, 12:50 AM
I drive over 80mph daily. The few times I've checked I've only been in 7th. 2017 TH.
future is offline
post #3 of 38 (permalink) Old 05-19-2017, 07:34 AM
Why, you think it changes by model year? In my 2014 I see 9th, usually over 80, absolutely flat or slight downgrade, light touch on the gas. I guess for those times it provides slightly better gas mileage. A purpose, if not a great one. And very exciting, like the Holy Grail. Are you saying I won't even see that when I pick up my 2017??
Granite Crystal Metallic
Idiotic Charging Pad
Wish I had the tow group...
mreg376 is offline
post #4 of 38 (permalink) Old 05-19-2017, 07:37 AM
I have never seen it either! What, me worry?
post #5 of 38 (permalink) Old 05-19-2017, 07:57 AM
ckl
ckl's Avatar
Haven't seen it yet, but haven't been out of the city yet.
From Tapatalk: the app that spams your signature line like a boss.
Vehicle of my dreams? Hmm ... always stay skeptical, but enjoy what you've got while you've got it.
ckl is offline
post #6 of 38 (permalink) Old 05-19-2017, 08:11 AM
I've never seen 9th on my '15 TH. I rarely drive it over 70mph anyway, just as long as the RPM's stay down I really don't care if it ever finds that mystical 9th gear.
mmahamm likes this.
'15 TH, 3.2L
mowcowbell is offline
post #7 of 38 (permalink) Old 05-19-2017, 09:11 AM
HawkeyeKL's Avatar
These Transmissions are made in Germany. I don't think they have a problem getting up to 9th gear speed legally. That is the problem. Not designed with US highway laws in mind.
HawkeyeKL is offline
post #8 of 38 (permalink) Old 05-19-2017, 09:25 AM Thread Starter
Dodgeboy's Avatar
Mreg wrote: <<Why, you think it changes by model year?>>
That was the question. The car has a 9-speed transmission that only uses 8 of its gears. Then what's the point of having a 9-speed? I think that's engineering that's somewhat lackluster. My '15 with the tow package has a 3.52 to 1 axle ratio. Change that to 3.9 or 4.1 and the car would probably be seeing 9th gear in normal cruising while having more acceleration in the lower gears.
It's not a matter of wanting to see the elusive 9th gear just for the thrill. It's to see the engineers properly match the capabilities of the transmission to the car. I think this is a 'bug' that they have apparently not worked out yet.
Dodgeboy is offline
post #9 of 38 (permalink) Old 05-19-2017, 09:31 AM
I've checked several times while doing 70+ and see 9th. On a slight downhill grade I will get into 9th at 70.
runnergeek is offline
post #10 of 38 (permalink) Old 05-19-2017, 09:38 AM
ua_who's Avatar
Or drop the ratios to the 4.1 or so (raise numerically) enough to only use 2nd through 9th.
Then in low range, you get to use first and have even better low end gearing.
ua_who is offline
9th Gear Frankt Transmission Discussion 37 03-12-2016 04:50 PM
Has anyone been about to get into 9th gear Rippin Engine and Technical Discussion 76 06-20-2015 08:01 PM
9th gear ... JD63 2014+ Jeep Cherokee General Discussion 20 10-15-2014 08:38 PM
9th gear Patrick25 2014+ Jeep Cherokee General Discussion 12 06-24-2014 09:47 AM
How to use 9th gear Acidsnow Engine and Technical Discussion 16 04-28-2014 08:04 PM
