Auto gear shift - Page 2 - 2014+ Jeep Cherokee Forums
 11Likes
post #11 of 24 (permalink) Old 06-13-2017, 04:39 PM
wpgguy's Avatar
Best piece of advise I could give is to read the manual. Not only will it tell you what you're doing wrong, but for the most part it will tell you everything you need to know.
Black Cherokee Sport 4x4 i4
Current Mileage: 56,000km
wpgguy is offline
post #12 of 24 (permalink) Old 06-13-2017, 07:32 PM Thread Starter
Thanks for all the replies. I have read the manual that came with the car and it says nothing about electronic range select. I understand what it is now and it shows up on the instrument panel. what is the highest gear it usually operates in mine says 9 and I can go down but 9 is highest. By the way I called Jeep and was told it is like a manual shift. I told him he better read more. I will download the manual and see if it is better than the one I got. Just downloaded the manual. it is much better and includes lots more than mine does. Thanks
country is offline
post #13 of 24 (permalink) Old 06-13-2017, 07:47 PM
then you didn't read it very well page 476 of your owner's manual
http://www.fcaworkvehiclesus.com/jee...page-fit,3,544
IRSmart is online now
post #14 of 24 (permalink) Old 06-13-2017, 08:36 PM
AlbertaCherokee's Avatar
The jeep guy was right if rpms are high enough it up shifts and downshifts if not over reving. It will downshift by itself but can be done manually. If your going 90 mph shifting into 9 even works.
The manual does not go into detail and does not cover all scenarios. The best way to learn it is use ers through all scenarios and have some fun. The ers is computer protected so drive it figure it out or never use it for sure fear!!
Raven olllllllo
AlbertaCherokee is offline
post #15 of 24 (permalink) Old 06-13-2017, 10:38 PM
wpgguy's Avatar
I'm not too sure what you're trying to say. I know if I leave the range select in 2nd gear and go it won't shift any higher even when redlining so be careful. If you have the range select set for a certain gear it won't shift higher than that gear. And the range does not have correlation between travelling 90mph and 9th gear...
Sent from my SM-G935W8 using Tapatalk
wpgguy is offline
post #16 of 24 (permalink) Old 06-14-2017, 06:47 AM
I was just being a little extreme for the 9th gear just trying to say you have to be going fast enough for it to get there.
All I'm basically saying is I can control my shifting up and down if I want to keep my revs higher in all gears. Like in city driving I can use sports mode full auto so rpms stay higher when taking my foot of gas. I can do the same using manual select mode. And a 3rd way way to increase rpm in full auto mode is to give the gas pedal a quick flick to drop down into a lower gear and you can do this repeatedly as your slowing down to get into a lower gear faster for engine breaking. I really think this transmission is cool and like it a lot for what it can do. Even when I come up to my garage door in auto mode I will flick my gas pedal to go from 3rd to 2nd to 1st.
So reading a manual for learning all about a vehicle is about the same as reading a manual and being knowledgeable at some of our other hands on activitieslike learning to ride a horse.
Raven olllllllo
post #17 of 24 (permalink) Old 06-14-2017, 06:42 PM Thread Starter
I did read every page of my manual it only goes to page 232. The one I downloaded and is complete.
country is offline
post #18 of 24 (permalink) Old 06-14-2017, 06:43 PM
Hi, I sent you a private message. Check your inbox.
post #19 of 24 (permalink) Old 06-15-2017, 09:33 AM
Here is another trick to downshift for breaking if you don't want to manually downshift a gear at a time.
NOTE: To select the proper gear position for maximum deceleration (engine braking), move the shift lever into the ERS position, then simply press and hold it forward (-). The transmission will shift to the range from which the vehicle can best be slowed down.
Raven olllllllo
post #20 of 24 (permalink) Old 06-15-2017, 11:29 AM
wpgguy's Avatar
It's not manual select though it's a range limiter. What you're using it for is fine but that's not what it's designed for and can be misleading to others who also believe it's a manual shift select. You can't upshift using the range selector as you're stating, if you're select a higher gear and it's upshifting it's because the transmission knows it should already be in the higher gear so it will upshift as intended, but it won't go higher than necessary. The range select is to limit the RPMs for towing and braking.
wpgguy is offline
Stuck gear shift lever Jaro360 Interior 1 09-14-2015 11:25 PM
4-5th gear shift? Purestrait Transmission Discussion 5 06-30-2015 09:39 PM
Gear shift from 1-3 spiegepj 2014+ Jeep Cherokee General Discussion 21 12-17-2014 07:34 PM
Gear shift lever Superflii Southern California 11 10-19-2014 08:59 PM
Air Condition/Shift into gear issue talulabelle Engine and Technical Discussion 6 08-06-2014 09:53 AM
