Auto gear shift - 2014+ Jeep Cherokee Forums
 11Likes
post #1 of 24 (permalink) Old 06-11-2017, 06:57 PM Thread Starter
Question Auto gear shift
My wife has a 2015 Cherokee and we love it. I have what probably is a dumb question but here goes anyway. The gear shift when in drive has a left shift into a plus / minus spot. What is it for. My wife got in there by mistake and could not shift to park. Thanks for any help
country is offline
post #2 of 24 (permalink) Old 06-11-2017, 08:02 PM
If you read the owners manual it will tell you all about it. That section is called Electronic Range Select it can be used to prevent the transmission from shifting too high. To shift out of this mode simply slide the selector lever back to the right and you can then shift it normally.
Len1304 is online now
post #3 of 24 (permalink) Old 06-11-2017, 09:31 PM
AlbertaCherokee's Avatar
It also works for shifting down or shifting up control your gears it also has rpm protection so you can't hurt anything. Great for city driving!
Raven olllllllo
AlbertaCherokee is offline
post #4 of 24 (permalink) Old 06-11-2017, 10:22 PM
It's also used with Hill Descent Control feature if you have it.
2017 Granite Crystal Trailhawk 2.4L I4 with the Hazard Sky Trailhawk+ Lift, Red Plasti-Dipped Emblems and a Uniden PRO520XL CB Radio. SOON-TO-BE upgraded with a Dobinson Suspension, RRO Super Sliders and some 245/75R17 <brand TBD> Tires w/Pinch Seam Mod
fryguy is offline
post #5 of 24 (permalink) Old 06-11-2017, 11:50 PM
04Freedom's Avatar
If you don't have a manual available, you can quickly get one in PDF format here:
https://www.mopar.com/jeep/en-us/car...rs-manual.html
Click on Add a Vehicle.
It is handy to have a copy on your phone if you want to look up something and the paper copy is not nearby.
ptram and SkipW like this.
04Freedom is offline
post #6 of 24 (permalink) Old 06-12-2017, 03:03 PM
Originally Posted by 04Freedom View Post
...It is handy to have a copy on your phone if you want to look up something and the paper copy is not nearby.
It's actually better than the paper copy. It's more up-to-date, and more comprehensive.
sgrim and 04Freedom like this.
Build date: 05-14-15, 33K miles as of 6/2016
Other vehicle: (wife's) 2015 Lexus RX450h 33K mi
mmahamm is offline
post #7 of 24 (permalink) Old 06-12-2017, 03:30 PM
Shifting up? It's ERS, Electronic Range Select, not a "Manumatic" system.
It lets you specify the max gear the transmission will take, not actually select the gear you want. As others have said, it's also used to control speed for hill descent/ascent.
wpgguy likes this.
Rojhan is online now
post #8 of 24 (permalink) Old 06-13-2017, 12:48 AM
The only use I have for it is it shows what gear I'm in.
Duke2015, Fj4080 and 04Freedom like this.
fumbling is offline
post #9 of 24 (permalink) Old 06-13-2017, 07:13 AM
Auto gear shift
For easy driving auto works fine and is safe but if you ever get into a situation like in tighter corners mountain driving you have better control slowing down before corner picking lower gear higher rpm and have motor pulling you through corner with slight acceleration than coasting through corners. Slow into corner and faster out at the apex of corner. Driving using the tach in combination with speedometer makes a good driver and a vehicle perform to it upmost. Driving off-road the same thing lugging engine so keep rpm up where it can help you going up or down.
Raven olllllllo
post #10 of 24 (permalink) Old 06-13-2017, 09:40 AM
I use this daily! You can switch in/out of it on the fly at any speeds. It's great for a variety of reasons which others have already mentioned. For me, it's mostly used to control my speed while going downhill. Also to keep the vehicle from going too high into gear, and shifting back and forth constantly while the hill momentarily levels out, while going uphill. Curvy, slightly hilly roads it's useful for keeping it from going into too high of a gear.
Another option I love, and use in place of this at times, is switching into Sport mode. The RPMs ramp up quite a bit when you first getting going from a fully stopped position, but after that, the vehicle handles so much better. Like the ERS above, Sport mode can also be switched in/out of on the fly.
BrilliantBlackLimited is offline
Stuck gear shift lever Jaro360 Interior 1 09-14-2015 11:25 PM
4-5th gear shift? Purestrait Transmission Discussion 5 06-30-2015 09:39 PM
Gear shift from 1-3 spiegepj 2014+ Jeep Cherokee General Discussion 21 12-17-2014 07:34 PM
Gear shift lever Superflii Southern California 11 10-19-2014 08:59 PM
Air Condition/Shift into gear issue talulabelle Engine and Technical Discussion 6 08-06-2014 09:53 AM
