Squeaky brake pedal and a bunch of goop down there (see photo) - 2014+ Jeep Cherokee Forums
post #1 of 8 (permalink) Old 06-13-2017, 09:49 AM Thread Starter
Brake pedal is always letting out squeaky sounds when slowly releasing the foot from it. In stop and go traffic it drives me insane. Literally, every release or minor release it makes a slow squeaky noise until the foot is all the way off the pedal or until I begin to apply the brake once again. I took a look down there and I see a bunch of gooey, yellow gunk. Not sure if this has always been there or if the dealership tried to apply it last year when I brought this issue to their attention.
Should I wipe this off or leave it? Should I spray something else down there, if so, what? It's hard to tell, but I'm pretty certain the noise is coming from that rubber area (not sure what that thing is called) with the yellow goo on it.
BrilliantBlackLimited is offline
post #2 of 8 (permalink) Old 06-13-2017, 12:59 PM
Mine does the same thing, I have yet to find a solution that lasts longer then a few weeks. You are correct though the noise is made by that metal shaft moving in and out of that rubber boot. It looks like someone has already attempted to fix yours with some type of white lithium grease. If its squeaking now, wiping that grease off isn't going to fix it.
Pitcherman is offline
post #3 of 8 (permalink) Old 06-13-2017, 03:29 PM
wpgguy's Avatar
Thats just white lithium grease, comes in a spray can. I used to use it on my steering shaft to fix the dreaded clunk there (my old Pontiac G6), usually works quite well but needs to be re-applied annually depending on where you're using it. Wipe it off and apply some more, make sure to work the break pedal in/out to get it in there.
Black Cherokee Sport 4x4 i4
Current Mileage: 56,000km
wpgguy is offline
post #4 of 8 (permalink) Old 06-13-2017, 03:47 PM Thread Starter
Thanks for the info! I'll try and get some more of the grease and reapply it.
post #5 of 8 (permalink) Old 06-13-2017, 03:58 PM
I had a similar problem on a different vehicle, it turned out to be the master cylinder making the noise
pete7713 is online now
post #6 of 8 (permalink) Old 06-14-2017, 12:13 PM
Maybe try WD-40? It always eliminates squeaks for me.
post #7 of 8 (permalink) Old 06-14-2017, 09:34 PM
take it to the dealer-do not spray anything in there- it will not help.
Squeak/spring noise from brake pedal
dumper is offline
post #8 of 8 (permalink) Old 06-17-2017, 11:31 AM
I have a non-goopy squeaking break pedal. Not obnoxious, but it's there. I asked the service department to check on it while in for scheduled maintenance and they said it was the brake booster itself. On-order for warranty work.
Maybe somebody tried to fix your squeak by loading it up with goop.
Rojhan is offline
Brake pedal Jiggle Cherry-kee 2014+ Jeep Cherokee General Discussion 11 11-07-2016 09:19 PM
In for squeaky break pedal, out with new trans Zoramac Transmission Discussion 10 08-05-2016 11:17 AM
Brake Pedal Noise Jeep Girl 2014+ Jeep Cherokee General Discussion 22 06-08-2015 11:06 PM
Brake Pedal Feel JRSJEEP Wheels, Tires, Brakes, and Suspension 3 05-05-2015 12:19 PM
Brake pedal noise cherokeeyeah 2014+ Jeep Cherokee General Discussion 4 09-12-2014 11:16 AM
