Trailing Arms, how to install? - 2014+ Jeep Cherokee Forums
post #1 of 2 (permalink) Old 06-15-2017, 06:32 PM Thread Starter
So, I have a 2017 Latitude AD1 and am going to instill the Hazardsky lift when it arrives. I would like to then add 245/70R17 Duratracs. I know some people have said they did need TH trailing arms and I plan to install those too.
Does anyone have any links to videos or descriptions of how to replace the trailing arms? Is this something I can do myself?
Thank you all.
Ninjastyle77 is offline
post #2 of 2 (permalink) Old 06-17-2017, 11:23 AM
rski's Avatar
yes you can do it yourself ..5 bolts on each one remove and replace with new trailing arms jack vehicle up and remove tire remove existing trail arm. and replace with new one.when you remove existing one you will have a little play in rear end to add new one as the bolt pattern is slightly different which put the rear end back into center after lift is installed .. line up holes on assembly end install bolts attach the other end to body afterwards do not do the body part first. hope this helps..
we also have a group buy going on in general discusion page for dobinson suspension lift kit 722.00 shipped just letting you know
2016 JEEP CHEROKEE SPORT ADI...LED INTERIOR, FALKEN WILD PEAKS A/T 3W 255/65/17, REPLICA TRAILHAWK GLOSS BLACK RIMS, PATRIOT URBAN DEFENSE COLOR SCHEME (HAZARDSKY/AUSSIE/VALPACER LIFT DESIGN) ROLA VORTEX CARGO BASKET, THULE RAPID CROSSBAR SYSTEM, EXTERIOR LED LIGHTS.GOBI LADDER , BLACK 5GL JERRY CAN
GOD BLESS THE REPUBLIC....
rski is online now
max tire size on trailhawk without lift Pacerized Wheels, Tires, Brakes, and Suspension 20 05-14-2017 11:39 AM
Lift Kit & Tire Size Chart BLKBEARDRED6 Wheels, Tires, Brakes, and Suspension 99 04-14-2017 07:06 PM
