I was working out in my pasture (fence work) and wanted to listen to some music. I opened all the doors, but had to shut the driver door as the door chime was ruining my musical experience :wink:. Does anyone know of a way to stop the chime so that I can open all my doors and crank some tunes?
The only thing I do is put the car in 'run' instead of 'acc' but not sure if that is bad for the car as I don't actually start it.
I only do that for short times.
I haven't found a way either...I just open all the windows and hatch and leave the driver's door closed. Also, this is only for a short time while loading or unloading...
Is the music on your phone or a blue tooth device? I paid $150 and got a JBL charge speaker that is fantastic. And you don't have to worry about door chimes or running your vehicle or anything. It's awesome.
/\ I also have one of the JBL BT speakers that is about the size of a beer can. It is incredible! Sounds great and has a great range. I use it on job sites where clients are not around...I tend to leave it in the trailer though....
If you manually close the latch on the door you can trick the door to thinking its closed... its remembering to "open" the latch again that's the pain. Theres been a few times ive slammed my door closed only to have it bounce back open... Ooops!
Thanks for the info. Was wondering if that would work. When @fryguy asked, I was about to suggest duct taping the door interlock switch down. Checked the KL's door jamb and it's not there :s. Then learned the door ajar switch is integral to the door latch mechanism of each door and the liftgate; and of course sends a signal to the BCM so other modules can feast on the info .
I thought there was some sort of trick to turn it off for people that like to drive with the door open while going over rocks.
Like turn the key to ACC and off 3 times open and close the door three times and spin around 3 times while saying some sort of chant.
