9th gear - 2014+ Jeep Cherokee Forums
 7Likes
post #1 of 13 (permalink) Old 06-23-2014, 05:27 PM Thread Starter
Patrick25's Avatar
Question 9th gear
So i got up to 9th gear..but when i was going 90.i go to check the gear and it said 7 but when i was going 70 mph..it said 9..im so lost about how changing gears works. Can someone explain it to me?
2014 Cherokee Granite Trailer Tow Group
Back up camera
3.2L VVT
FWD
Patrick25 is offline
post #2 of 13 (permalink) Old 06-23-2014, 05:37 PM
RojStock's Avatar
I don't know why it chooses the gear it chooses I just let it do it's thing. I'm sure it has something to do with the load on the tranny and not just pure speed but that's as far as I go.
I think I'm more concerned with people taking pictures of their dash while speeding down the highway. Just a general request from the board as I've seen this more then a few times on here ... please, no more dash pics unless stopped. We'll believe you, and if we don't, who cares what we think.
dawhitesTH, clew, PeteB and 2 others like this.
RojStock is offline
post #3 of 13 (permalink) Old 06-23-2014, 05:40 PM
lfbar's Avatar
I was hoping maybe they had someone show how taking the pictures for them.
Sport FWD I4
cold weather group
back up camera
compact spare tire
lfbar is offline
post #4 of 13 (permalink) Old 06-23-2014, 05:47 PM
dawhitesTH's Avatar
that's my take on it.
dawhitesTH is offline
post #5 of 13 (permalink) Old 06-23-2014, 05:51 PM
Milan's Avatar
From my experience, the 9th kicks in at about 85 mph, on a slight downhill road. Probably at even slower speed with some tailwind, or on a different grade. You also have to understand that at higher speeds (such as 90) the air resistance increases dramatically and the transmission needs to shift down to provide enough torque to keep you going.
Anyhow, that's not something you should be concerned about. Your transmission does the best it can, with respect to desired speed and gas mileage.
Hope it helps
Trailhawk V6/Granite/Tow
Milan is offline
post #6 of 13 (permalink) Old 06-23-2014, 05:56 PM
Originally Posted by Milan View Post
...the transmission needs to shits down...
Apparently for many on this forum, their transmissions have been having that problem too.
mbucklein likes this.
post #7 of 13 (permalink) Old 06-23-2014, 06:09 PM
Milan's Avatar
I'm not sure what problem you are referring to. I just tried to explain the OP why his transmission shifted down @ 90 mph, and that there is nothing problematic about that.
Milan is offline
post #8 of 13 (permalink) Old 06-23-2014, 06:13 PM Thread Starter
Patrick25's Avatar
Very well explain @Milan now I understand.
Back up camera
3.2L VVT
FWD
post #9 of 13 (permalink) Old 06-24-2014, 01:55 AM
Milan's Avatar
If you are concerned about gas mileage, again from my experience, the sweet spot on a flat road is at about 60-65 mph in 7th gear. This is also where you'll find your vehicle the most responsive to throttle. At least with a V6 engine.
Milan is offline
post #10 of 13 (permalink) Old 06-24-2014, 04:18 AM
JeepDog's Avatar
We are used to cars shifting up into successively higher gears as we accelerate. But it never goes into 9th while accelerating, at least not at speeds of 87 or less... not for me so far any way. I've seen 9th at speeds between 75 and 87. It only goes into 9th when you're at a high speed AND you slack off on the throttle to a level to just maintain speed on flat or slight downgrade. It's kind of a super-overdrive gear that it uses when it determines there is no longer a need for a gear that is any lower, basically when there is no load on the engine. But the second the engine gets a load on it, say from pressing the accelerator or transitioning to a slight upgrade, it kicks down to a lower gear.
Life is bumpy. Drive a Jeep.
JeepDog is offline
9th Gear? Trailhawked 2014+ Jeep Cherokee General Discussion 73 08-31-2015 06:57 AM
Has anyone been about to get into 9th gear Rippin Engine and Technical Discussion 76 06-20-2015 08:01 PM
MPG and 9th Gear techguy505 Engine and Technical Discussion 40 10-31-2014 05:04 PM
How to use 9th gear Acidsnow Engine and Technical Discussion 16 04-28-2014 08:04 PM
9th gear? Mainejeeper 2014+ Jeep Cherokee General Discussion 6 02-13-2014 11:29 AM
