Engine Stop Start (ESS) - Page 36 - 2014+ Jeep Cherokee Forums
 209Likes
post #351 of 360 (permalink) Old 04-07-2017, 01:33 PM
Xinarin13's Avatar
But you shouldn't be stopped at an interaction with the wheels turned. If you get hit from behind it shunts you into oncoming traffic!
I think that if I get hit hard enough from behind to push me 10 - 20 feet in any direction that I have bigger problems lol
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is offline
post #352 of 360 (permalink) Old 04-07-2017, 09:38 PM
I've only driven 2000 miles with my 2017 Latitude but I really dislike the ESS. If I drove a lot of stop and go city driving with long lights it might be worth it but in my case ESS is simply an annoyance and I really wish I could permanently disable it. There is no good reason for the engine to shut down for the very few minutes I wait at traffic lights and stop signs each day. I disable ESS every time I start the engine and curse every time I forget to and it engages. I also wonder how long the starter motor will last with ESS and how much it costs to replace it? My 2 cents.
2017 granite crystal Latitude ADII, 3.2, Uconnect 5.0 with 9 speakers, cold weather, safety and convenience, more to come.
CherokeeFred is offline
post #353 of 360 (permalink) Old 04-08-2017, 05:17 PM
I got the lifetime mopar warranty since I plan to keep this TH for a very long time, so not a concern for me but if it ever happens I'll update this thread. For now, after direct experience with ESS, it is not as big an annoyance as I initially thought.
fumbling is offline
post #354 of 360 (permalink) Old 04-08-2017, 05:39 PM
.... I also wonder how long the starter motor will last with ESS and how much it costs to replace it? My 2 cents.
Covered under your powertrain warranty. FWIW, the starter, battery, and flywheel gearing are beefed up plus other electrical enhancements and uses special clutch in trans for ESS.
Xinarin13 likes this.
post #355 of 360 (permalink) Old 04-08-2017, 09:14 PM
don't think starter is covered under powertrain warranty
E. Parts Covered
The Powertrain Limited Warranty covers these parts and
components of your vehicle’s powertrain supplied by
FCA US:
Gasoline Engine:
cylinder block and all internal parts; cylinder head
assemblies; timing case, timing chain, timing belt, gears
and sprockets; vibration damper; oil pump; water pump
and housing; intake and exhaust manifolds; flywheel
with starter ring gear; core plugs; valve covers; oil pan;
turbocharger housing and internal parts; turbocharger
wastegate actuator; supercharger; serpentine belt tensioner;
seals and gaskets for listed components only.
Transmission:
transmission case and all internal parts; torque converter;
drive/flex plate; transmission range switch; speed sensors;
pressure sensors; transmission control module; bell
housing; oil pan; seals and gaskets for listed components
only.
N
Array likes this.
pete7713 is offline
post #356 of 360 (permalink) Old 04-08-2017, 09:32 PM
Thanks for the heads up. Guess it stands to reason, like other attachments like alternator, etc.
Makes that Mopar Max Care Warranty even more attractive.
pete7713 and fumbling like this.
post #357 of 360 (permalink) Old 04-20-2017, 10:08 AM
JeepCherokeeClub.com Vendor
whitexkr's Avatar
SmartStopStart ESS default memory device now available!
ESS: As this thread demonstrates either you love it, hate it or somewhere in between. Arguments can be made on all sides.
If however you want to set the default in your Cherokee to ESS disable, there is now a plug and play solution. See http://www.smartstopstart.com/
This was developed with the help of several members of this forum who offered their cars as Beta testers. I thank them for their support! There is related discussion also in this thread: http://jeepcherokeeclub.com/4-2014-j...etro-area.html
www.SmartStopStart.com 3.2L V6 Engine Stop Start (ESS) the way it should have been designed.
whitexkr is offline
post #358 of 360 (permalink) Old 04-20-2017, 10:12 AM
Hippogriff's Avatar
If this is 'flipping some bits'... could the same facility be made available so the wing mirrors auto-fold, instead of pressing that silly button?
David_Baker likes this.
Cheers, Hippo
Hippogriff is offline
post #359 of 360 (permalink) Old 04-20-2017, 10:16 AM
whitexkr's Avatar
No guarantees, but I might add more features in the future. I do not know offhand whether the auto mirror control id feasible or not. My policy though, is free exchange upgrades for 2 years for the cost of shipping if features that you want are added.
rpasetto likes this.
whitexkr is offline
post #360 of 360 (permalink) Old 04-20-2017, 10:20 AM
rpasetto's Avatar
.. also makes this "SmartStopStart" system more attractive :-)
... RP
2015 Trailhawk
Ordered 8/6
Took Delivery Sept. 12, 2014.
rpasetto is offline
Start/stop video Bucky Engine and Technical Discussion 29 08-18-2014 11:18 PM
Remote Start with Start/Stop, Will it work MooseMax 2014+ Jeep Cherokee General Discussion 9 08-08-2014 02:46 PM
2015 Stop Start and Adaptive Learn pksurfish 2014+ Jeep Cherokee General Discussion 22 08-06-2014 08:50 PM
More Cherokee Start/Stop Information ekmeister Engine and Technical Discussion 8 07-04-2014 11:00 PM
2015 V6 Cherokee to get Stop-Start Technology PeteB Engine and Technical Discussion 108 06-26-2014 12:39 PM
