9th gear ... - 2014+ Jeep Cherokee Forums
 7Likes
post #1 of 21 (permalink) Old 10-09-2014, 11:03 AM Thread Starter
9th gear ...
I must say , it's a deep sense of satisfaction when 9th kicks in on my daily commute .
Thank you Jeep for a wonderful vehicle
JD63 is offline
post #2 of 21 (permalink) Old 10-09-2014, 11:15 AM
PCRit's Avatar
I never see 9th gear on my commutes. But I did pay attention recently, and actually saw that it exists on my recent trip! I usually saw it when going >76mph when going down hills, since I never drive faster than 75 when I'm on interstates... Now I just note when the RPMs drop from ~1750 (when I'm usually in 8th gear), down to ~1500 rpm, which is where 9th gear is seen.
Jeepster1 and zzjdzz like this.
Anvil 2014 Trailhawk 3.2L
Comfort-Conv Pk / Leather Pk
Sunroof/8.4-NAV/Towing Pk
Build Date 3-14-14
PCRit is offline
post #3 of 21 (permalink) Old 10-09-2014, 12:26 PM
Same for me but I think it can't be too steep a hill because maybe engine breaking kicks in.
2014 Latitude Deep Cherry Red.....
3.2L V6 AD1
Towing Group
Uconnect® 8.4A
Backup Camera
Build 5/31/14
chartle is offline
post #4 of 21 (permalink) Old 10-09-2014, 02:04 PM
How do you enable the gear display? I only see drive "D"
duasto is offline
post #5 of 21 (permalink) Old 10-09-2014, 02:32 PM
PCRit's Avatar
Gently bump the gear shift knob to the left, the gear number will show where the D is on the display.
Build Date 3-14-14
PCRit is offline
post #6 of 21 (permalink) Old 10-09-2014, 03:36 PM
Justin327's Avatar
I usually cruise in 7th on my commute....I think I've seen 8 once or twice, I never hit 9 without shifting in myself.
Justin327 is offline
post #7 of 21 (permalink) Old 10-09-2014, 03:41 PM
ua_who's Avatar
8th here happens very regularly. 9th is under perfect conditions, and has happened less than a dozen times probably over the last 10 months. (and even then, just for very short distances)
zzjdzz likes this.
ua_who is offline
post #8 of 21 (permalink) Old 10-09-2014, 04:51 PM Thread Starter
I guess I'm lucky . I have a five mile freeway decline on the way to work and then back home,
on a 22 mile each way trip .
Provided no-one suddenly pulls out in front of me it stays in 9th at about 1300 rpm on the decline
at about 75mph to 60ish .
Sometimes it will go into 9th on a long flat stretch , but not for long .
JD63 is offline
post #9 of 21 (permalink) Old 10-09-2014, 06:14 PM
I never saw 8th till I hit 2,000+ miles. It was always in 7th.
Now anytime between a low of around 62 to 70+ I am in 8th. That is unless I am on a hill.
9th on a downhill at 74mph and my foot off the gas. I did not see 9th till I hit 3,000+ miles.
Also you can not shift into 9th. You can only set 9th as your high gear.
The transmission will determine what gear it will use. It will not use 9th that I know of.
You can only limit the top gear it is allowed to use.
Like when I tow I set the high gear that the transmission is allowed to use as 7th.
Also when my Cherokee started to use 8th my mpg increased noticeably, very noticeably.
Turtle likes this.
post #10 of 21 (permalink) Old 10-09-2014, 06:27 PM
PCRit's Avatar
Yes, mpg is much better when cruising in 8th, which is most of my hwy driving between 70-75. I haven't towed anything yet, but will in the future...as such I only limit the high gears when going down very steep hills and use either 7 or 6 (very steep grades).
Build Date 3-14-14
PCRit is offline
9th Gear? Trailhawked 2014+ Jeep Cherokee General Discussion 73 08-31-2015 06:57 AM
Has anyone been about to get into 9th gear Rippin Engine and Technical Discussion 76 06-20-2015 08:01 PM
9th gear Patrick25 2014+ Jeep Cherokee General Discussion 12 06-24-2014 09:47 AM
How to use 9th gear Acidsnow Engine and Technical Discussion 16 04-28-2014 08:04 PM
9th gear? Mainejeeper 2014+ Jeep Cherokee General Discussion 6 02-13-2014 11:29 AM
