Service Shifter - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 17 (permalink) Old 11-26-2014, 11:53 AM
Lcrngrs's Avatar
Originally Posted by bradster View Post
Hoping that is all it is. Thanks!
That is exactly what they will do. I had the same problem. I posted back in may and no one here had the problem so I had to go through the gyrations of bringing the car three times before they figured it out. That was even after my own research told them what the problem was. Bottom line, the shift knob has to be replaced.
Lcrngrs is offline
post #12 of 17 (permalink) Old 11-28-2014, 06:35 PM Thread Starter
bradster's Avatar
Shifter control module being replaced. Of course it is on back order and I'm looking at next Wednesday as the earliest I will get it back. My loaner is a Chevy Sonic....can't get much worse.
bradster is offline
post #13 of 17 (permalink) Old 12-01-2014, 10:47 AM
Lcrngrs's Avatar
Why leave the car? I just brought it back when the part came in.
Lcrngrs is offline
post #14 of 17 (permalink) Old 12-09-2014, 06:31 PM Thread Starter
bradster's Avatar
LCRNGRS, Unfortunately, my TH wouldn't always go into gear, and also wouldn't change gears on the highway which resulted in driving at high RPM's in a low gear.
bradster is offline
post #15 of 17 (permalink) Old 12-09-2014, 06:37 PM Thread Starter
bradster's Avatar
Update: A total of 18 days at the dealer waiting on a part that was backordered. They replaced the shifter and performed the following updates. Reprogram Module, Radio Frequency Hub (RFH), Power train control (PCM), and Instrument Panel Cluster (IPC). Fingers crossed that I'm done with my issues.
bradster is offline
post #16 of 17 (permalink) Old 12-10-2014, 01:47 PM
Lcrngrs's Avatar
Gotcha. I'm glad things worked out. Fingers crossed.
Lcrngrs is offline
post #17 of 17 (permalink) Old 06-18-2017, 12:28 AM
I have a 2014 Jeep Cherokee North - 40,600km.
The "Service Shifter" message has been coming on for the past month. The dealership said that can't find anything wrong because it always resets itself once the car is turned off. They want me to drive it to them when the message is displayed - its too bad that they aren't open 24/7, then maybe I could get there when it is acting up.
Also, the transmission was repaired twice and replaced a week ago. The Service Shifter message was coming up before the transmission troubles became apparent. It is still shifting roughly from 1 - 2 and R. So far, the cost (under warranty) is close to $7k.
I read that there is a class action lawsuit in the states because of these issues with the 2014 Cherokee.
What is next in Canada?
Nikki9 is offline
Service Shifter error message Lcrngrs 2014+ Jeep Cherokee General Discussion 61 05-29-2017 02:21 PM
Gear shifter lights question tjarget Engine and Technical Discussion 2 11-05-2014 12:21 PM
Shifter noise Billet Steel Engine and Technical Discussion 11 06-27-2014 07:45 PM
Parking service warning light on dash, just got it back from service jeepgirl19 Wheels, Tires, Brakes, and Suspension 2 06-22-2014 04:48 PM
Shifter problem? angem29 Engine and Technical Discussion 7 04-01-2014 02:40 PM
