Lug Nuts? Nope. Bolts! - 2014+ Jeep Cherokee Forums
 15Likes
post #1 of 29 (permalink) Old 11-22-2014, 08:27 PM Thread Starter
Dodgeboy's Avatar
I looked up a set of locking lug nuts for the Cherokee and found that they were pretty pricey. So I went out and pulled a lug nut off the Jeep to check its size (I know, I've had it a day and I'm taking it apart already - can't help myself).
Anyway, this is what we have holding our wheels on:
Not lug nuts but lug bolts! Must be that European influence. (VW, Audi, MB, Volvo, BMW...)
The good: The threads are protected and less likely to rust. The bad: Lining up the wheel can be a pain.
The threads seem to be 12mm. The hex is 19mm or 3/4".
scott5626 and rumrunner like this.
Dodgeboy is offline
post #2 of 29 (permalink) Old 11-22-2014, 08:59 PM
Mudman1's Avatar
Yup, I saw this when the tire shop mounted my new shoes. They bolt into the rotors. Like you said, VW and others have been doing this for years. So long as they don't break, I am cool with it.
Mudman1 is offline
post #3 of 29 (permalink) Old 11-22-2014, 09:06 PM
DrCloud's Avatar
Originally Posted by Dodgeboy View Post
... Lining up the wheel can be a pain.
The hex is 19mm, and because they want 100 ft-lbs of torque, 19mm is the better choice of socket.
Although lining the wheel up is more difficult, getting it on in the first place is easier -- you just put it on the hub, and it hangs there while you rotate it up to get the first bolt started. It's actually easier than having to align the wheel while lifting it. HPH
Array, LeoKnightas and rumrunner like this.
Why: Wilderness is not a luxury but a necessity of the human spirit and as vital to our lives as water and good bread ... We need the possibility of escape as surely as we need hope. -- E. Abbey
Getting there:
On-road: Cashmere/Frost Beige, 2015 Cherokee Latitude 4x4 w/ 3.2L V-6; Cold & Tow Groups; Uconnect 8.4A w/Nav; 18” summer (Firestone Firehawk A/S tires), 17” winter (ArcticClaw tires)) wheels; Yakima crossbars.
Off-road:Full-time 4x4 wheeling.
DrCloud is offline
post #4 of 29 (permalink) Old 11-22-2014, 09:11 PM
onefunkar's Avatar
actually it comes with a long bar in the spare tire area. you screw it in where the lug bolt comes out and use it to guide the tire and wheel on. used it when rotating tires and it works great..
Array, TedB, LeoKnightas and 2 others like this.
onefunkar is offline
post #5 of 29 (permalink) Old 11-22-2014, 09:51 PM Thread Starter
Dodgeboy's Avatar
<<actually it comes with a long bar in the spare tire area. you screw it in where the lug bolt comes out and use it to guide the tire and wheel on.>>
That's a great tip. I knew that they made guides like that but didn't know that one came with the Jeep.
Dodgeboy is offline
post #6 of 29 (permalink) Old 11-22-2014, 10:00 PM Thread Starter
Dodgeboy's Avatar
<<...and because they want 100 ft-lbs of torque...>>
Is that the 'official' wheel bolt torque? Good to know.
Dodgeboy is offline
post #7 of 29 (permalink) Old 11-23-2014, 12:40 AM
@onefunkar - Thanks for the tip on the alignment pin. Here's some stuff from the manual:
7. Remove the alignment pin from the jack assembly and
thread the pin into the wheel hub to assist in mounting
the spare tire.
Torque Specifications
Lug Nut/Bolt Torque - 100 Ft-Lbs (135 N·m)
**Lug Nut/Bolt Size - M12 x 1.25
Lug Nut/Bolt Socket Size - 19 mm
**Use only Chrysler recommended lug nuts/bolts and
clean or remove any dirt or oil before tightening.
007 likes this.
post #8 of 29 (permalink) Old 11-23-2014, 05:15 AM
Toy
Toy's Avatar
Exact, that's the European style of mounting wheels
The only reason for that is, the threats could not be damaged when placing wheel on the hub.
rumrunner likes this.
German Cherokee KL and Renegade BU Forum
http://www.new-jeep-forum.de
Toy is offline
post #9 of 29 (permalink) Old 11-23-2014, 10:54 AM Thread Starter
Dodgeboy's Avatar
I think having two of those wheel guide pins would be handy to have around the garage. Screwing two onto the hub would make mounting the wheel a snap. I wonder what they cost?
Edit: I found them aftermarket. What the conversion from Euros to dollars?
http://www.autoinparts.com/Wheel_nuts,_bolts,_locks,_spacers_and_accessories-Quick_Align_Wheel_Tool/c628_962/p112626/Quick_Align_Wheel_Tool_-_M12_x_1.25_Thread_-_Fiat_Fitment/product_info.html
Here are some really nice ones but unfortunately not available in the 1.25 thread pitch: http://www.autowerksofamerica.com/pr...guide-tool.htm
Dodgeboy is offline
post #10 of 29 (permalink) Old 11-23-2014, 12:17 PM
onefunkar's Avatar
not sure what they cost but after rotating tires one works fine. made it pretty easy to line up.
Cherokee=No studs and wheel nuts! 14SDJeep Wheels, Tires, Brakes, and Suspension 19 05-03-2015 05:30 PM
replacement wheel bolts MLHooper Wheels, Tires, Brakes, and Suspension 12 10-01-2014 12:40 AM
convert to suds and lug nuts w/ spacers Jenk Wheels, Tires, Brakes, and Suspension 14 05-02-2014 01:04 PM
Wheel bolts?? DarthBauer Wheels, Tires, Brakes, and Suspension 4 02-27-2014 06:46 PM
