ZF Transmission geometric calculator - 2014+ Jeep Cherokee Forums
  • 2 Post By eak
post #1 of 2 (permalink) Old 04-10-2016, 09:55 PM Thread Starter
eak
eak's Avatar
I just found this on another forum.
http://www.jeepgarage.org/f216/has-t...d-96037-3.html
Apparently the 9 speed transmission is also a rocket engine.
CHECK THIS OUT.....
This is an INTER-ACTIVE webpage below....... CLICK PLAY in the top left corner.... the interactive controls are at the BOTTOM.
https://upload.wikimedia.org/wikiped...P_Nomogram.svg
This interactive nomogram is a real geometric calculator exactly representing the rotational speeds of the transmission's 3x4 = 12 internal shafts for each of its 9 ratios (+ reverse), grouped according to their 5 permanent coupling on 4 joint ordinates and 3 independent ordinates. These ordinates are positioned on the abscissa in strict accordance with the proportions of the sun gears' teeth numbers relative to those of their rings. Consequently, the output ratios on the 6th ordinate (carrier of the fourth planetary gearset) follows closely those of the actual transmission. This advantageous geometric construction sets us free from Willis' famous and tedious formula, because all calculations are exclusively determined by lengths ratios, respectively teeth numbers on the abscissa for the 4 epicyclic ratios, and of rotational speeds on the 6th ordinate for the 10 gear ratios.
Usage:
Select the gear with the corresponding right button.
(Restore all gears with All button)
Adjust the 4 planetary gearsets dimensions with 4 bottom sliders.
(Reset to factory settings with Rst button)
Legend:
A : Dog Clutch (couples r1+s2 with input shaft)
B : Clutch (couples s1 with input shaft)
C : Brake (blocks s1 sun gear)
D : Brake (blocks r2 ring gear)
E : Clutch (couples c3+r4 with input shaft)
F : Dog Brake (blocks s3+s4 sun gears)
ZF 9HP
http://wiki.epfl.ch/polymac/document...-Schematic.png
Mudman1 and sgrim like this.
Lake Orion, MI
Granite Crystal Metallic Date ordered: 03/Jan/2014 Delivered: 4/Mar/2014
Granite Crystal Metallic TH KL •|||||||•| 3.2L V6 24V VVT | 27E | 9-Spd 948TE 4WD
TOW |Comfort Convenience | Brown Leather | Technology| Uconnect 8.4AN
Cold Weather | Black Hood Decal | 9 Amplified Speakers w/Subwoofer | CD
eak is offline
post #2 of 2 (permalink) Old 04-11-2016, 11:45 AM
ptram's Avatar
I would say that is "Greek" to me but I had a year of Greek over 40 years ago and remember a couple of words--more than I understand your quote--LOL
ptram is offline
KL RPM Calculator David_Baker Engine and Technical Discussion 4 11-14-2016 12:17 PM
