200+ Mile Drive after S55 Recall - 2014+ Jeep Cherokee Forums
 3Likes
post #1 of 13 (permalink) Old 11-27-2016, 01:48 AM Thread Starter
R2D2's Avatar
Hi Guys,
I wanted to share my thoughts on the new S55 Recall. I took my 2014 TH to the dealer yesterday to get the S55 Recall Update. They've updated the TCM and my ECU.
My first initial drive, right off the bat. I can tell that my TH shifts SO MUCH smoother. Previously a shift from 1-2, 2-3, is a rough shift. Then 3-4 you can tell there is a huge lag(dog clutches) and then another kind of rough shift . Now everything is smooth. You don't feel a nudge nor a rough shift any more.
Now the treacherous 3-1 stop and go issue. Previously, you must be at a complete stop to reach 1'st gear. And the Cherokee does not shift to 2nd on a rolling stop. Now, I've checked and done this so many times. On a rolling stop, the Cherokee does still stay on 3rd but you can feel the quick shift to 2nd then to 3rd.(Verified this when I felt the car shift by quickly moving the shifter to "Manual" and shows the current gear) I can now do a rolling stop without worrying to gas the car to make it go faster and to make it shift into a lower gear or stop worrying about a rolling stop and gassing the car and it stays on third. Let me tell you how its embarrassing how the car sounds and feels when I have friends in the car and tells me "Dude, why does your car feel like that".
I've done a short stop and go traffic, so far the way my transmission shift is actually smoother than before. It stays on 1st much longer instead of the tranny trying to shift to 2nd which makes the car jerk a little bit and then back to 1st.
I just thought I'd share my thoughts on the new S55 Recall. I will update this with more information once I find more interesting updates.
CaliEcoGreen, sgrim and Mark_ like this.
R2D2 is offline
post #2 of 13 (permalink) Old 11-27-2016, 02:34 AM
Normandy's Avatar
Originally Posted by R2D2 View Post
Hi Guys,
My Sep 2015 th goes in this Friday , not sure of there will be any updates of software , just was told wire harness repcement , takes an hour , that's all I have been told . Will report if three are any differences
Victorian Highlands Australia
Normandy is offline
post #3 of 13 (permalink) Old 11-27-2016, 08:19 AM
Had my S55 couple weeks ago on my 2014 Limited. Only 1 update prior to this one.
There were update(s) that are part of the S55 recall. FCA probalbly added in some shift improvements and especially adjustments to the 3/1 downshift issue, that were addition to the S55 adjustments.
But again that is a guess on my part and from my observation of the results.
I agree that the 1/2 and 2/3 shifts are the most noticeable. This update actually seems to have smoothed out those shifts. Now, I had no issues with them before but there is a further improvement and now almost unnoticable.
That is unless I am a bit heavy on the gas out of the gate.
As far as the 3/1 downshift its hard to tell as I do not get a lot of stop and go driving. I use to get a jerk at times when accelerating from a roll while slowing down. Not all the time but maybe at just the right speed and acceleration point. Have not really noticed that since the update but will pay attention and give it more time.
Seems to have been a beneficial update besides covering the S55 issue if it should ever occur.
post #4 of 13 (permalink) Old 11-27-2016, 10:25 AM
I've put a couple hundred miles on since S55 and there has been no change. However, the shifts have been smooth since R01. But accelerating out of a slowdown from 1 - 12 mph has the same delay and surge as it shifts from 3rd to 1st or 2nd. So, no change here.
post #5 of 13 (permalink) Old 11-29-2016, 06:38 PM
Normandy's Avatar
no recall for june onwards 2015
Just got a call from my local JEEP dealer, they have just been sent a note from Jeep that all TH exports made on or after June 2015 do NOT need the S55 recall... so no recall for me!
Normandy is offline
post #6 of 13 (permalink) Old 11-29-2016, 08:33 PM
I've had the S55 almost two weeks now. They did the reflashes. They've done reflashes before, so it all seemed routine. I can't tell if its my imagination or if its more tangible, but after every reflash they've performed, the tranny always seems to be smoother. I've never experienced the many issues noted by others on this forum, so there never has been any drastic changes. I do think that it is smoother since S55.
post #7 of 13 (permalink) Old 11-30-2016, 05:33 AM
What are outside temps for you this time of year. We got the S55 a few weeks ago and We have been noticing that under 40 there is a huge lag on a 3-2 when on a slight incline. it seems 3-2 downshift is held back when the transmission is still cold which creates the lag because there is no enough torgue in 3rd. It is a very hard shift and jerk. Never had this issue last winter.
Problem goes away when transmission warms up. However the problem is very dangerous every morning leaving our neighborhood onto the main street.
We are in a little warm spell with rain but next week when the cold returns I plan on call jeep and asking for a case to be opened.
johonn is offline
post #8 of 13 (permalink) Old 11-30-2016, 09:32 PM
jamie1's Avatar
I did the S55 recall on wires Cherokee today. Only had the flash the TCM. Never told my wife to expect anything different on how it may shift. She came home tonight saying how much SMOOTHER the transmission shifts, so maybe FCA did do something else with the flash.
jamie1 is offline
post #9 of 13 (permalink) Old 12-01-2016, 07:55 AM
My understanding was there were some adjustments with this software patch besides the fix for the possible future crimping of the cable. Now, I would imagine it would depend on what level of software your Cherokee is on and the year of it. My 2014 had only one update to date. That was a May 2014 update I got on May 2015. As far as any improvements as mentioned earlier, 1/2 and 2/3 smoothed out. But while noticeable they were subtle changes.
Glad it worked out great for you. Got to keep the wife happy. I can imagine if it went the other way!
post #10 of 13 (permalink) Old 12-01-2016, 10:12 AM Thread Starter
R2D2's Avatar
A little update from me:
Its been almost a week now and I've noticed a lot. I have driven my TH for 25k before the S55 recall.
I've noticed that on "Auto" it feels a little similar to "Snow". For example, on "Snow"; the TH starts on 2nd gear to avoid any wheel slippage. When you gas the car you can feel the car shift quickly to third. But for what ever reason on "Auto" it starts on 1st gear then quickly shifts to 2nd gear then to 3rd. I may be imagining things but thats how the car feels.
I've been on a stop and go situation for a week now. I'm very happy with this update, no more sudden shifts to 2nd then back to 1st along with a jerk. It seems to hold first gear longer and then quickly shifts smoothly to second.
On rolling stops as I suspected between 1-9 mph. The transmission does stay on third but while rolling then gassing the car it quickly shifts to 2nd(I can feel it shift and see on my dash that its on 2nd gear) so you can safely go faster. This is great because it usually stays on 3rd gear and when you gas the car, it can feel either sluggish or a burst of power because it shifts to 1st.
I haven't gone off-road since May so we'll see how it fairs on dirt. I doubt theres going to be any change. Oh Yeah I have a new rear-diff since July. It will be great to test out the S55 update and the new rear diff.
R2D2 is offline
S55 recall NZOLIVER Australia 5 11-14-2016 12:37 PM
S55 Recall Parts Shipping Around 10/20 KepeliTH 2014+ Jeep Cherokee General Discussion 17 11-03-2016 02:24 AM
S55 Transaxle wire harness recall 2015 Wolfdog 2014+ Jeep Cherokee General Discussion 1 09-13-2016 12:55 AM
Recall S55 JohnAdam 2014+ Jeep Cherokee General Discussion 1 09-08-2016 06:33 PM
Another FCA 9 Speed Recall - Chrysler 200 gti337 2014+ Jeep Cherokee General Discussion 2 02-26-2015 03:50 PM
