9 speed fluid service? - Page 2 - 2014+ Jeep Cherokee Forums
 6Likes
post #11 of 16 (permalink) Old 01-13-2017, 02:51 AM
US manuals say lifetime, export say 120,000km change (about 70,000 miles)
post #12 of 16 (permalink) Old 01-13-2017, 01:45 PM
Desoto's Avatar
I can't find that on the Export Maint. For 120km all I see is:
◾Change the engine oil and engine oil filter. *
◾Replace the engine air cleaner filter.
◾Rotate tires.
◾Inspect the CV joints.
◾Inspect the front suspension, boot seals, tie rod ends, and replace if necessary.
◾Inspect brake linings, replace if necessary.
◾Inspect parking brake function.
◾Replace the air conditioning/cabin air filter.
◾Replace the engine fuel filter.
◾Replace accessory drive belt. **
◾Replace timing belt. **
◾Change brake fluid.
Desoto is offline
post #13 of 16 (permalink) Old 01-13-2017, 01:49 PM
◾Rotate tires.
It seems they have their own little schemes, at least in Australia they do. Some places in Europe too. I base this on forum members posting about routine service costs imposed by their local FCA *authority*. It's really bad in Australia, owners are being robbed blind... and they can't even do their own oil changes...
David_Baker likes this.
post #14 of 16 (permalink) Old 01-14-2017, 07:28 AM
◾Rotate tires.
You should be the poster child for severe service for your vehicles. And I mean that in a good sense.
*Now any particular maintenance you have or plan on doing for the transmission, like fluid changes, or are you treating it as a lifetime no service item.
* Also the important item you mention is the Timing belt. I was under the impression it was a chain which should last longer than a belt.
I know when I asked the Chev dealer on my wife's '04 Chev. recently (which she refuses to part with) he just said it will start making noise when its at its life end.
But again thanks for your insight into this Cherokee and your helpful advice.
post #15 of 16 (permalink) Old 01-14-2017, 08:20 PM
I was going to comment on the belt too. The manual is non vehicle specific and their is a deisel version that does have timing belt (prob what the two ** are beside the entry).
post #16 of 16 (permalink) Old 01-15-2017, 07:42 AM
That is my concern as a chain usually lasts a long time and does usually give some warning before failing.
A belt is very finite in lifespan and failure usually results in engine damage depending on valve set up.
In the past I have replaced timing belts at 70k (US) just to be safe when my vehicle had one.
Service Airbag, Service Parking Brake, and traction control out all hit at once. rpeytonp 2014+ Jeep Cherokee General Discussion 14 07-27-2016 07:12 PM
service 4wd/ service brake light Harrod1170 2014+ Jeep Cherokee General Discussion 9 06-03-2016 05:45 AM
Windshield washer fluid teo Engine and Technical Discussion 13 04-26-2016 10:39 PM
Transmission fluid question a320ca Engine and Technical Discussion 13 01-08-2015 08:13 AM
Parking service warning light on dash, just got it back from service jeepgirl19 Wheels, Tires, Brakes, and Suspension 2 06-22-2014 04:48 PM
