High RPM's During Normal Shifting when Engine Cold - 2014+ Jeep Cherokee Forums
 1Likes
  • 1 Post By Mark_
post #1 of 4 (permalink) Old 01-13-2017, 07:51 AM Thread Starter
C3PO's Avatar
Usually early in the morning on the first start of the day, or sometimes in the afternoon but usually on colder days, when I pull the jeep off the driveway it waits to shift into 2nd gear after about 3K-4K RPMs and I always prepare for the hard engagement because its spinning way to fast for the next gear. This happens in 1st, 2nd and 3rd. This usually goes away shortly but on my short 5 min. drive to work is killing me.
My foot is also *barely* on the accelerator. In other words, there is nothing I can do to cause it to shift sooner. I've also tried shifting manually but obviously that was to no avail as that's only useful for shifting at higher RPM's anyways.
This is a brand new 2017 cherokee trailhawk, and I have been treating it with kid gloves- especially now- so as to not make anything worse. Anyone know what it could be? Something wrong with the sensor that tells the KL when to shift? I want to avoid the dealership as much as possible and use warrantee only for emergencies.
2017 Cherokee Trailhawk V6 All Black
-Comfort & Convenience
-Cold Weather
-SafetyTec Package
-Command View Panorama Sunroof
-9 Speaker Sound System
-Tow Package
-8.4in Nav System
C3PO is offline
post #2 of 4 (permalink) Old 01-13-2017, 09:44 AM
Mine does the same thing, but the revs do not go as high as yours. I think that they must be programmed to do this in cold weather, to be able to get cabin heat sooner. Once mine is warmed up, it stops doing this. My MPGs when cold outside drop to 13.5 to 14.5, from my normal 18.5 to 19.5, mostly city driving.
post #3 of 4 (permalink) Old 01-13-2017, 11:03 AM Thread Starter
C3PO's Avatar
Not a chance. We are talking about different things.
My jeep will literally wobble during the shifts that's how hard the engagements are, and like i said, it doesn't matter how soft my foot is, if i want to drive more than 20 kph at a decent rpm i have to push out of that 1st gear by revving it up so high -probably causing damage every time i do so. This repeats for 2nd and 3rd gear as well. By the time i get to 4th its not so bad, but repeat that for every stop sign/light.
This is 100% unnatural, I just want to know if anybody knows what could cause this? Trans fluid? Sensors? Software issue?
Also any other 2017 owners experienced this, and if so do you think its related to cold weather?
-Cold Weather
-SafetyTec Package
-Tow Package
-8.4in Nav System
C3PO is offline
post #4 of 4 (permalink) Old 01-13-2017, 11:16 AM
Sorry I have a 2015. But what you describe there sounds very alarming. You will have to visit the dealership. My advice : tell them to let the Jeep sit outside overnight and let the tech start it up in the morning and take a test drive. Tell them how long you let it warm up before you leave in the morning, so they can compare with your situation.
Mine *bangs* into 2nd when it's cold. By cold I mean whenever the outside temp is below 10C (or 50F) in the morning, so basically every morning where I live. If I drive away without warming it up for at least 2 minutes, it will bang into 2nd, even I barely accelerate and am only going 10mph. Revs don't go that high, mine will upshift below 2500 RPM when it does this. But yours is totally different...
The only TSB I've found for 2017 shifting issues is for a delayed Reverse to Drive situation. 2016s and below have a bunch of different TSBs for different shifting anomalies, but not 2017s... yet.
Have this investigated asap, to prevent possible permanent damage to your tranny/drivetrain...
fdegree likes this.
Cold engine won't start for high temp Wheyman Engine and Technical Discussion 7 10-05-2016 03:14 PM
Unusually high RPM on sport mode (video) Djungo Transmission Discussion 6 02-02-2016 05:54 PM
EXTREME low power / High RPM w/ A/C on ari_nj 2014+ Jeep Cherokee General Discussion 18 07-21-2015 11:31 AM
High RPM's - Is this a problem? tjarget Engine and Technical Discussion 18 10-09-2014 10:08 PM
Normal shifting question? gundad Engine and Technical Discussion 3 07-18-2014 08:54 AM
