8th gear at 54 mph---is this normal? - Page 2 - 2014+ Jeep Cherokee Forums
 4Likes
post #11 of 17 (permalink) Old 02-05-2017, 02:51 PM
thebige88's Avatar
I use my ScanGauge to see what gear it's in. You can set the gauge to show many different functions as it's plugged to the OBDII reader in the vehicle. One of those options is "Current Gear". I also like set another of the 4 gauges to show "GPH" gallons per hour as it really lets you see where the best fuel efficiency at a given RPM. Normally get 21mpg in the city and 26 mpg Hwy. @ 74 mph.
2014 Billet Silver - Gand Canyon Brown Interior3.2 TH, Tow, Comfort&Convenience. AVS vents, Door Molding, Red brake calipers and NO hood sticker. Order May/7/14 received July/11/14 Currently 32,200 miles. No serious problems just the usual updates.
thebige88 is offline
post #12 of 17 (permalink) Old 02-05-2017, 05:00 PM
I keep mine in MPGs all the time. I'll try the shifter trick tomorrow. Thank you.
post #13 of 17 (permalink) Old 02-05-2017, 05:12 PM Thread Starter
ptram's Avatar
It works--I found it on here myself several months ago by another poster. Basically, all you have to do is pull your shifter over to the left when in D and then either pull it up or down to the small letter reads 9 and then you will see every time it shifts when going forward. I do enjoy seeing where mine shifts at every gear and how it does going up and down inclines.
ptram is offline
post #14 of 17 (permalink) Old 02-05-2017, 07:05 PM
Renthorin's Avatar
For me, I don't see 8th until 60mph.
Renthorin is offline
post #15 of 17 (permalink) Old 02-05-2017, 07:52 PM
I just went out to the garage to try it. I've done this before: if I move the lever to the left, it says 1 and will stay in 1 until I move the lever to 2. By pulling the lever back, and going all the way to 9 must change the transmission from manual mode back to auto mode (I'm guessing!). I'll try it out in the AM. It's like another Easter Egg!
post #16 of 17 (permalink) Old 02-05-2017, 08:22 PM Thread Starter
ptram's Avatar
Yeah, if you put it in 9th with your lever that only means it will not go any higher than 9th (which of course is all you have anyhow) and you will see all the shifting it does in the forward gears. It is fun for me to see what it is doing and if I notice any hard shifting at particular gear changes which I haven't felt any on my current TH.
ptram is offline
post #17 of 17 (permalink) Old 02-08-2017, 10:15 PM
detroitmikeb's Avatar
Originally Posted by ptram View Post
The 2016 and 2017 shifter can be pushed to the left and then either pull back(can remember) or push forward till it shows 9th gear.
I can do this in my 2015 as well. Up to the lower gears, down to the higher gears (should be the other way around but whatever).
2015 Jeep Cherokee Trailhawk
Granite Crystal Metallic
3.2L V6 4x4
K&N Drop-In / 20% Tint
Aftermarket Alpine Setup
detroitmikeb is offline
Transmission Is Inconsistently Choosing 8th Gear fdegree Engine and Technical Discussion 20 09-24-2016 03:01 PM
Wobble in 8th Gear Rojhan The JCC Lounge 1 08-16-2015 02:12 PM
MPH for 8th Gear? Dodgeboy 2014+ Jeep Cherokee General Discussion 18 08-10-2015 12:35 AM
when will I see 8th gear? Renthorin Engine and Technical Discussion 26 11-25-2014 04:53 PM
8th Gear Oddity Dallara101 Engine and Technical Discussion 27 02-20-2014 07:12 PM
