8th gear at 54 mph---is this normal? - 2014+ Jeep Cherokee Forums
 4Likes
post #1 of 17 (permalink) Old 02-04-2017, 03:01 PM Thread Starter
ptram's Avatar
I noticed today that my 2017 Th v-6 goes into 8th gear at between 52 and 55 mph on a flat surface road. It is still in 8th at about 74 mph and I didn't go any higher as I don't like the idea of a ticket for testing my TH. The rpm at about 55 mph was about 1300 rpm. The transmission is doing great--hardly even tell it is shifting unless I am watching it like I was today, I know this is old stuff and a lot of threads, but maybe I was sleeping before as I never noticed any of my other KLs going into 8th gear at between 52 to 55 mph. No, complaints, just enjoyed the 70 mile drive today in the sunshine here in SC.
ptram is offline
post #2 of 17 (permalink) Old 02-04-2017, 03:08 PM
Operating as intended. Mine (2015) is similar. Computer will allow roughly 1300rpm with the V6, but not lower. 1300-1500rpm is the mpg sweet spot.
9th with the V6 is only seen starting at roughly 75mph and above, either going downhill, with a strong tailwind or drafting.
post #3 of 17 (permalink) Old 02-04-2017, 03:17 PM
i wish mine shifted into 8th that quick! with the roof basket, light bar, and lift, it doesn't like high gears at all anymore, and i get between 15-17 mpg.
Ordered and waiting for arrival: RRO brush bumper & pre-runner plate - RRO rock rails - Spot & flood lights mounted to bumper - MFC switch plate w/OTRATTW custom switches
post #4 of 17 (permalink) Old 02-04-2017, 06:00 PM Thread Starter
ptram's Avatar
Wow--I am surprised it is making that much of a difference. I usually accelerate pretty fast at every stop and go (when I hit a red light and first in line) and I had a lot of them today when I was in Greenville and my computer still said I was getting about 20.7 today which is good for me. (computer was only about three tenths of a mile off from actual check with use of gas last time I checked.)
ptram is offline
post #5 of 17 (permalink) Old 02-05-2017, 09:12 AM
limey-g's Avatar
My 2017 Limited v6 goes into 8th gear at a lower speed than my 2014 ever did, something I commented on recently.
limey-g is offline
post #6 of 17 (permalink) Old 02-05-2017, 09:32 AM
And let's not forget that the factory Tow Group, with its shorter final drive ratio, allows getting into a higher gear at slightly slower speeds (a few mph). Depending on driving speed, this can even prove to be an advantage for fuel economy, as surprising as it may sound to some.
post #7 of 17 (permalink) Old 02-05-2017, 12:12 PM
How are you guys/gals determining what gear you are in? Are you just feeling the shift, or watching the tach? If I push my shifter to the left, it will stay in a gear until I move the shift lever. Is there a way around this?
post #8 of 17 (permalink) Old 02-05-2017, 12:19 PM
Moving the shifter over momentarily will show you what gear you're in. That's how people are determining it.
post #9 of 17 (permalink) Old 02-05-2017, 12:20 PM
With time, I can tell now just by looking at the RPM vs speed. But the only way to tell for sure is to move the shifter over briefly and see the current gear. I don't leave it there, because doing so prevents upshifting. So just a quick look.
post #10 of 17 (permalink) Old 02-05-2017, 12:29 PM Thread Starter
ptram's Avatar
The 2016 and 2017 shifter can be pushed to the left and then either pull back(can remember) or push forward till it shows 9th gear. And then it will show what gear you are in while driving as you will seldom hit 9th gear. The 9th gear is a smaller number besides showing the actual gear you are in at the time. Of course when you have to go in reverse you have to move the shifter back to the normal location and then when going forward re-do the procedure. It is really nice to be able to see when the gears are shifting. I didn't explain this too well, but someone will hopefully make it more clearly. (lwhen you put it in 9th gear as the highest gear it will go too--this doesn't prevent it from shifting from 1st to 9th gear and letting you see it shift)
ptram is offline
Transmission Is Inconsistently Choosing 8th Gear fdegree Engine and Technical Discussion 20 09-24-2016 03:01 PM
Wobble in 8th Gear Rojhan The JCC Lounge 1 08-16-2015 02:12 PM
MPH for 8th Gear? Dodgeboy 2014+ Jeep Cherokee General Discussion 18 08-10-2015 12:35 AM
when will I see 8th gear? Renthorin Engine and Technical Discussion 26 11-25-2014 04:53 PM
8th Gear Oddity Dallara101 Engine and Technical Discussion 27 02-20-2014 07:12 PM
