First little bump on my 2017 transmission--- - Page 2 - 2014+ Jeep Cherokee Forums
 7Likes
post #11 of 21 (permalink) Old 03-04-2017, 11:47 PM
04Freedom's Avatar
Originally Posted by ptram View Post
I put it in D thinking I would get going as others were waiting to pick up other people in the same area. Well, in D, I didn't go anywhere--just like it was in Neutral and a message came up. I am not sure what the message was as I was in a hurry to get out of there--may have been to go to Park and then something else--
I do not recall exactly what I did, but two times I have had a message pop up and tell me I had to shift to Park. Each time I was sitting still. I think I had shifted to Neutral from Drive, and because it sat in Neutral for an "extended time" of merely several seconds, it's like the electronic brain wanted it to go back to Park before I could select Drive again.
I think the sequence was:
Shifted from Drive to Neutral
Stayed in Neutral several seconds
Attempted to shift back to Drive, but it wouldn't and message said to shift to Park.
Shifted to Park then to Drive and all was well.
04Freedom is offline
post #12 of 21 (permalink) Old 03-05-2017, 12:21 PM
Arrow
Unless I'm missing something, isn't that the way it's supposed to work?
According to the book, seat belt fastened, foot on the brake, move shifter to R or D and it will auto unlock. It doesn't say anything about touching the gas pedal. I just discovered this work-around by giving it some gas as I was backing out of my garage. The rear end began to lift up. I gave it a little more gas, and it unlocked the e-brake. I could hear it as well as feel it!
post #13 of 21 (permalink) Old 03-05-2017, 01:21 PM
Yeah, my wife thinks it sounds like a Transformer.
Here's what my 2015 owner's manual says:
"The parking brake will release automatically when the
ignition switch is ON, the transmission is in Drive or
Reverse, the driver seat belt is buckled, and an attempt is
made to drive away
Array is online now
post #14 of 21 (permalink) Old 03-05-2017, 04:05 PM
Thumbs up
made to drive away
I guess this would mean giving it some "gas". At times, mine refuses to unlock automatically.
post #15 of 21 (permalink) Old 03-05-2017, 05:45 PM
Mine was like that when new. I have the auto park brake feature turned on and it gives in real easy now. Maybe it learns over time?
Array is online now
post #16 of 21 (permalink) Old 03-14-2017, 07:08 PM
04Freedom's Avatar
I basically duplicated the occurrence below by accident except I put it in Reverse after being in Neutral for several seconds. Put it in Reverse, and it was functionally still in Neutral. Goofy quirk. Probably explained in the owner's manual some where.
post #17 of 21 (permalink) Old 03-14-2017, 07:33 PM
Duke2015's Avatar
I know exactly what it was, it was the collision detection, the moment someone walks infront of your jeep, or behind, the dash will make a sound and slam on your brakes, it is working as intended and that is why it did not leave a error message. ty yw.
Duke2015 is online now
post #18 of 21 (permalink) Old 03-14-2017, 09:00 PM
totomojo's Avatar
I have had this happen... at a long light I have shifted to neutral and taken my foot off the brake. After about 5 seconds I get a chime and a message appears on the dash (that I ignored the first time it happened) that I need to press the brake and shift back into gear if I want to proceed.
If I shift into drive without pressing the brake it acts like I am still in neutral when I press the gas. A bit disconcerting the first time it happens.
Array and Duke2015 like this.
2017 KL TH, 3.2 liter V6, Comfort/Convenience Group, Tow Package, Panoramic Sunroof, Black painted wheels, best car stereo I have ever heard.
Bone white and bone stock (so far)
totomojo is offline
post #19 of 21 (permalink) Old 03-14-2017, 09:59 PM
Duke2015's Avatar
wow i tested it, it chimed and gave me that notice and everything, nice find
totomojo likes this.
post #20 of 21 (permalink) Old 03-15-2017, 01:50 PM
04Freedom's Avatar
You just nailed it!
2nd Rear Tow hook mod and bump guard Black 'Hawk Exterior 38 03-01-2017 08:39 AM
New 2017 KL TH Cudarich New Member Introductions 10 02-19-2017 01:07 AM
Adaptive learning, shifting, accelleration and things that go bump. Rojhan Transmission Discussion 2 10-20-2015 03:20 PM
Hit a bump, change the input basicwizz Electronics, Audio, and Lighting 10 10-11-2015 12:54 AM
Conquering the bump stops geoelectric Wheels, Tires, Brakes, and Suspension 13 12-17-2014 07:51 PM
