Service Transmission - 2014+ Jeep Cherokee Forums
 9Likes
post #1 of 21 (permalink) Old 03-04-2017, 11:43 AM Thread Starter
generaltso's Avatar
I had my 14 Cherokee at the dealer last week for the transaxle wiring crimp recall. They said that it didn't need a new part, so they just did the software flash specified in the recall. Not sure if it's related or a coincidence, but today the EVIC is showing "Service Transmission". When I shift to drive, sometimes it will clunk hard into gear, but D is flashing so I think it's in limp home mode. Other times when I shift to drive, nothing happens. The D flashes, but it seems to stay in neutral.
I just had it towed back to the dealer. I guess I'll have to wait and see what they find.
2014 Jeep Cherokee Limited V6 ADII - built 4/21/14
Granite/Morocco Black - Every option except the block heater
generaltso is offline
post #2 of 21 (permalink) Old 03-04-2017, 03:50 PM
Question
Has anyone had their transaxle wire harness replaced under the S55 recall? Or heard about someone getting it replaced?
post #3 of 21 (permalink) Old 03-04-2017, 03:59 PM Thread Starter
generaltso's Avatar
When mine was in for the recall, the dealer said they had only had to replace the wire harness in one Cherokee so far. All the others were just the firmware flash.
Array and 007 like this.
post #4 of 21 (permalink) Old 03-04-2017, 10:24 PM
Which is why I am avoiding going in for the recall....your story exactly.
post #5 of 21 (permalink) Old 03-05-2017, 07:02 AM
Probably screwed up the update on the TCM that replaces the need for the harness replacement in most cases.
My harness recall went fine and only needed the software update. Actually it seemed to run a bit better.
Only has had 1 update before that on my 2014 Limited.
Now the only other thing I can think of is the harness was actually defective and they missed it on the check.
Now your Cherokee is doing what it is suppose to do when the harness crimps. That is it goes into limp mode instead of stalling out on the side of the highway.
But I am sure your dealer will figure it out.
Good Luck and let us know the solution.
post #6 of 21 (permalink) Old 03-05-2017, 08:12 AM Thread Starter
generaltso's Avatar
Thanks. They were going to "try" to look at it yesterday, but I didn't hear anything so I guess they couldn't fit it in. I hope they can get to it tomorrow. I'll post back when I get an update.
post #7 of 21 (permalink) Old 03-05-2017, 10:43 AM
Desoto's Avatar
I have replaced 2 of them. Symptoms were the same. No engagement after a hot soak condition. No limp mode. All normal after a short cool down. Dealer was unable to verify.
Desoto is offline
post #8 of 21 (permalink) Old 03-05-2017, 10:55 AM Thread Starter
generaltso's Avatar
Replaced wiring harness or full transmission?
post #9 of 21 (permalink) Old 03-05-2017, 11:36 AM
Desoto's Avatar
Jjust the harness.
Desoto is offline
post #10 of 21 (permalink) Old 03-06-2017, 02:53 PM Thread Starter
generaltso's Avatar
I just got a call from the dealer. They verified that it's got the latest flashes installed, and they don't think the problem is related to the recall. They've opened a Star case with Chrysler and are waiting to hear back with next steps.
Service transmission light came on drdre89 Transmission Discussion 20 02-16-2016 04:07 PM
Service Transmission Came on Today Swede Transmission Discussion 27 01-14-2016 10:24 PM
Service Transmission....1 year old! TrainerX8 Transmission Discussion 41 03-06-2015 03:22 PM
Service transmission 3 times jfr Engine and Technical Discussion 3 12-31-2014 05:16 PM
Service Transmission on loaner develmann 2014+ Jeep Cherokee General Discussion 10 06-13-2014 12:08 AM
