Questions about flashing transmission - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 12 (permalink) Old 05-04-2017, 09:23 AM
Originally Posted by SkipW View Post
They did all outstanding recalls and updates. And, as I imagined, the only issue is the transmission...
Shifting quality has degraded, but not drastically. I notice lower gear lags and rougher shifts 1-2, 2-3, 3-4 and down as well, and I end up with 3rd gear during rolling stops and revs with little power about half the time.
I have also seen about a 2 MPG drop in mileage. Although I have yet to make a decent highway trip to see if anything is different there.
It is not a radical change, just what I had been trying to avoid, as my trans was doing beautifully up until I took the plunge.
Hopefully its just a lirttle AL because of that update. I know I was a bit sluggish and lost 8th after my only update and took a while to return. My MPG was down also but returned after a while. In my case 7th rather than 8th on the highway was the reason mostly.
post #12 of 12 (permalink) Old 06-11-2017, 08:28 PM
jeepreaper's Avatar
This being off topic a bit. How has your Update (1st one) been working out for your Cherokee. I know you had a standing order for the dealer not do updates.
Just curious. Thanks.
Has the operation of your transmission improved at all over the past month?
jeepreaper is offline
Flashing Odometer jp2014 2014+ Jeep Cherokee General Discussion 38 04-29-2016 01:51 PM
Flashing Odometer and No Chimes HowlingMad Electronics, Audio, and Lighting 1 09-01-2015 06:13 PM
Flashing Odometer KepeliTH Electronics, Audio, and Lighting 4 06-21-2014 07:15 PM
Engine / transmission questions Michelle Engine and Technical Discussion 10 05-30-2014 11:17 AM
flashing odometer reading JIruns Engine and Technical Discussion 2 03-13-2014 01:49 PM
