Transmission replacement - Page 3 - 2014+ Jeep Cherokee Forums
 19Likes
Closed Thread
post #21 of 24 (permalink) Old 05-14-2017, 10:46 AM
jamie1's Avatar
Originally Posted by mreg376 View Post
None of that makes much sense, and I don't quite understand about ZF supplying gaskets or not. I've read several times over that FCA builds the transmissions based on a license from ZF.
Yes,FCA does make our transaxles under license. I can only guess it is part of the license agreement that no parts are supplied for repairs. Same goes with ZF 8-speed used the trucks, no parts are available except for the trans pan.
Array and dhh3 like this.
jamie1 is offline
post #22 of 24 (permalink) Old 05-15-2017, 10:55 AM
I am not sure why you folks attack the OP since none of you know what his vehicle is doing. They replaced the valve body on mine, then the the trans withh a brand new trans (not rebuilt) and it still was horrible. Mine started to act up after a software update. FCA bought back my lemon. I have since put 20k on a BU TH and it is quite a bit better, however far from good.
14latitude likes this.
2015 TH Anvil 3.2 most options
2016 Renegade TH Anvil on order
2015 Audi SQ5
'You are not Sancho"
sciond is offline
post #23 of 24 (permalink) Old 05-15-2017, 12:53 PM
I don't think anyone was attacking the OP, I, for one, could not figure out what he was complaining about -- the price he paid (which he didn't tell), the current value (which he didn't tell), or the fact that the car (which he gave no details about) had a defect that was fixed under warranty. The only conclusion was that he was looking for a vehicle that never needed repair.
Granite Crystal Metallic
Idiotic Charging Pad
Wish I had the tow group...
mreg376 is offline
post #24 of 24 (permalink) Old 05-15-2017, 03:15 PM
I think we can end this thread as it has devolved into a circle....
Closed Thread
Transmission Replacement Silverswitch Transmission Discussion 10 06-15-2016 09:03 PM
Transmission Replacement Mike Nieman 2014+ Jeep Cherokee General Discussion 5 08-16-2015 02:28 AM
Transmission replacement :( Purestrait Transmission Discussion 1 03-07-2015 07:46 PM
Transmission Replacement on the way...... eeecia Engine and Technical Discussion 22 03-06-2015 11:36 PM
Pending Transmission Replacement WILLYS48 Engine and Technical Discussion 10 11-10-2014 04:58 PM
