Dry rot tires - how long do I have with them? - 2014+ Jeep Cherokee Forums
 7Likes
post #1 of 35 (permalink) Old 06-02-2016, 04:35 PM Thread Starter
I ran over a big ole screw on the highway couple days ago, thankfully it was just small enough to still be eligible for patch.
Local shop told me I've got dry rot, and I confirmed visually later the cracks in between my treads. I haven't done a complete inspection yet to see for evidence in the sidewall.
He gave me a "before winter" answer on lifespan, but his tone indicated that as absolute max.
Through google search I've found a range of opinions, but many saying it can be very dangerous to drive on, the tires can split at any time, their efficacy has been compromised, etc.
Thoughts? Also, I've got 225/65 17 on right now, an opinions on widening out to 265/65 17?
Finally, his recommendation were the pirelli scorpion verde all-season plus, and there are lots of good reviews on those. Does anyone have experience with them?
EDIT: Probably should have mentioned: 2014 Cherokee 2.4l AWD latitude
EDIT 2: pictures of the dry rot
eorlas is offline
post #2 of 35 (permalink) Old 06-02-2016, 04:40 PM
Hi,
You have a Latitude, correct ? I'm not sure 265/65s would fit. Not only are they wider, but somewhat taller as well. I think they fit on THs and perhaps AD2s, but maybe not on an AD1 Latitude (or Sport).
How many miles do you have on the tires ? Are they the Firestone Destination LE2s ?
Thanks..
post #3 of 35 (permalink) Old 06-02-2016, 04:41 PM
mults's Avatar
Don't know how a tire can get dry rot in 2 years (unless you live in the Sahara Desert). Typically, it takes about 5 years in the elements, but without seeing pictures, it is hard to say for sure. Maybe a second opinion is in order...just my 2 cents. Don't want to take tires issues lightly.
By-the-way, how many miles on the tires?
Mark_ likes this.
mults
mults is offline
post #4 of 35 (permalink) Old 06-02-2016, 04:43 PM Thread Starter
Hi,
Thanks..
Yes, Latitude! Can't believe I missed that too. How do I check if I have AD1 or 2 Latitude?
The car is ~51k miles, I bought it used last October at ~42k miles. Was my first used purchase, and I didn't ask about the last time tires were changed, so probably never.
They are indeed Firestone Destination.
eorlas is offline
post #5 of 35 (permalink) Old 06-02-2016, 04:45 PM
@mults :
I've had winter Yokohamas (Geolanders) that dry rotted pretty quickly, and it was a bad batch of them. I still rolled on them until they wore out, but I did take some risks there. I wasn't aware the Firestones had a rotting problem.
post #6 of 35 (permalink) Old 06-02-2016, 04:46 PM Thread Starter
Would it be prudent for me to snap a few and attach them back here?
eorlas is offline
post #7 of 35 (permalink) Old 06-02-2016, 04:48 PM
I guessed Latitude because of the tire size
As far as AD1 vs AD2 goes : if you have "Neutral" and "4Lo" on the range select knob (next to the shifter), then you have AD2. AD1s don't have Neutral or 4Lo.
At 51K miles, the Firestones are likely done, rot or not. I would replace them.
post #8 of 35 (permalink) Old 06-02-2016, 04:58 PM
mults's Avatar
Got a guy at work with about 50k on his tires (2014 Trailhawk) and they look almost new. Wouldn't replace if there is tread left, but if dry rotted, then definitely...
mults
mults is offline
post #9 of 35 (permalink) Old 06-02-2016, 05:12 PM
Not the same Firestones (LE2 vs A/T), but I am surprised the A/Ts can go well over 50K. I've heard and read the LE2s don't last very long, if you compare to eco tires or Michelins, for example.
Rotting sounds like a bad batch of tires, but I guess warranty is out of the question now...
@eorlas : can you check thread depth on those Firestones ?
post #10 of 35 (permalink) Old 06-02-2016, 05:16 PM Thread Starter
With a copper Mr. Lincoln?
eorlas is offline
How long did your factory brakes and tires last? TrailhawkExpress 2014+ Jeep Cherokee General Discussion 40 05-01-2017 12:26 PM
aFePOWER Pro Dry S Air Filter Install Video! JeepKL Engine and Technical Discussion 15 10-07-2016 05:06 PM
Dry Flow Drop in Panel Filter jim_87 Engine and Technical Discussion 6 09-30-2015 08:10 AM
How do you dry the Cherokee after a wash? cspaced Washing & Detailing 33 07-11-2015 03:08 PM
New Dry Transmission stoge Engine and Technical Discussion 9 04-19-2014 07:25 PM
