Leveled out my 2wd - Page 2 - 2014+ Jeep Cherokee Forums
 14Likes
post #11 of 43 (permalink) Old 08-24-2016, 01:16 PM
@MetalVox I would have loved to wait for a lift/leveling kit before I upgraded, but I need tires soon. I have stock TH rims on my FWD. Do u think I can go up to 275/55/17 at stock height with TH rims with 31mm offset? Ur setup is very close to what I am trying and there's nothing conclusive available for the FWDs on the forum. 275/55/17 is 28.9 inches tall and 10.8 inches wide. Thanks
Sent from my LG-VS985 using Tapatalk
MyThirdJeep is offline
post #12 of 43 (permalink) Old 08-24-2016, 01:18 PM Thread Starter
MetalVox's Avatar
Originally Posted by MyThirdJeep View Post
@MetalVox. You do realize you are about to be a hero for the FWD masses.. don't you?
nah man lol
in all honesty, regardless of whether its 2wd or 4wd, the underpinnings of this vehicle are the same for the front end. the difference is just finding something more cost effective, not to say the only available kit isnt awesome because it is. I work in the auto industry and have worked in the aftermarket side things as well so I know and understand costs and consumer pricing for items.
2015 Latitude FWD
18x8 Black Rhino Warlord's
255/60R18 Pirelli Scorpian ATR's
Custom Lift
Custom Short Ram Air Intake
R.R.M. Aluminum Crank Pulley
MetalVox is offline
post #13 of 43 (permalink) Old 08-24-2016, 01:24 PM Thread Starter
MetalVox's Avatar
the height is fine but the width is a bit much. you may have use a 1/4" wheel spacer so the sidewall doesnt rub on the strut body. you could run 235/65R17 which would be a perfect fit and give better options for tires as well as better pricing.
2015 Latitude FWD
Custom Lift
MetalVox is offline
post #14 of 43 (permalink) Old 08-24-2016, 01:39 PM
All hail metalvox!!!
BLKBEARDRED6 is offline
post #15 of 43 (permalink) Old 08-24-2016, 01:41 PM
Just trying to go widest on a street/ highway tire. I have my lifted WJ for the trails.. this 2WD KL is the gas sipper drive for the everyday 100 mile commute.
post #16 of 43 (permalink) Old 08-24-2016, 02:03 PM
Budget Boost works for FWD
Guys, budget boost does work with fwd, I've done this mod already on my fwd. It added approx 1" to 1.25" of lift. I'm looking to add an additional 1"
The kit comes with 2 spacers for the rear, I opted to install only one to somewhat level out the rear with the front when raising the front via the strut adjustment.
I'm wondering if the OP's alternative option is using spring boosters?
My Mods:
- 255/55 18" BFG KO2S
- XenonDepot HID kit
- Inexpensive 5.0 to 8.4 Uconnect upgrade.
- Inexpensive cloth to leather upgrade.
Jeep#2 is offline
post #17 of 43 (permalink) Old 08-24-2016, 02:08 PM Thread Starter
MetalVox's Avatar
take into consideration of the added weight of the much larger tire, which will affect mpg. just make sure to run a spacer if you go that big. id consider looking at low-rolling resistance tires to help offset the mpg lost.
2015 Latitude FWD
Custom Lift
MetalVox is offline
post #18 of 43 (permalink) Old 08-24-2016, 02:10 PM
Sweet! Thanks man. I like your set up.
post #19 of 43 (permalink) Old 08-24-2016, 02:10 PM Thread Starter
MetalVox's Avatar
yes, the budget boost would work no problem. The spacer is merely peace of mind for some, necessary if you actually wheel it.
2015 Latitude FWD
Custom Lift
MetalVox is offline
post #20 of 43 (permalink) Old 08-24-2016, 02:14 PM
Are you using spring boosters as your method?
My Mods:
Jeep#2 is offline
Jeep : Cherokee 2WD Country NO RESERVE...2WD...UNCOMMONLY CLEAN...2WD Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 09-21-2014 08:20 PM
Jeep : Grand Cherokee 2WD Limited New 2014 Jeep Grand Cherokee 2WD Limited MSRP $4807 Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 06-18-2014 09:20 PM
Jeep : Grand Cherokee 2WD 4dr Lare NO RESERVE 2007 JEEP GRAND CHEROKEE LAREDO 2WD RUN Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 05-29-2014 05:00 PM
Jeep : Grand Cherokee 2WD 4dr Limi Grand Cherokee 2WD RARE MercedesPowered 3.0L Turbo Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 02-26-2014 09:10 PM
Jeep : Grand Cherokee 2WD 4dr Limi Grand Cherokee 2WD RARE MercedesPowered 3.0L Turbo Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 01-21-2014 07:30 PM
