Lift Kit & Tire Size Chart - Page 6 - 2014+ Jeep Cherokee Forums
 36Likes
post #51 of 90 (permalink) Old 09-12-2016, 08:50 PM
Palms's Avatar
They are a LT version or Light Truck. They are also approx 12mm tread as opposed to about 9 or 10mm tread for the D rated passenger version. I ran the E LT version with no lift and very very minor rubbing at the back edge of the front wheel well, both with and without the lift. Yes they are stiffer and a little firmer ride but the suspension foes a good job making up for it.
Man I really like the look of your bar and antenna. Can you please give the details? Thanks!!
Palms is offline
post #52 of 90 (permalink) Old 09-13-2016, 12:40 AM
shayne10's Avatar
Originally Posted by Zoramac View Post
For the list
245/65 = 29.5 - stock
255/65 = 30.1
245/70 = 30.5
265/65 = 30.6
255/70 = 31.1 - no spacers or grinding needed (very light brushing at full lock)
245/75 = 31.5
265/70 = 31.6
255/75 = 32.1
So for a lifted sport I could fit 265/70r17?
shayne10 is offline
post #53 of 90 (permalink) Old 09-13-2016, 03:56 AM
PM sent with a link and an explanation!
post #54 of 90 (permalink) Old 09-13-2016, 05:49 AM
airishfan's Avatar
I like your tires and I can see you have a 15 TH is it worth the money getting them even that stock tires are still good
airishfan is offline
post #55 of 90 (permalink) Old 09-13-2016, 10:44 AM
Alfrik's Avatar
TIL I will eventually be giving RRO more money. A new lift kit from them with increased travel and lift? Now I wonder if I can add HazzardSky's to the lift as well.
Alfrik is offline
post #56 of 90 (permalink) Old 09-13-2016, 11:31 AM
I have 245/70r17 duratracs but the 4ply not the 10ply. Why go with such a heavy tire for such a lite vehicle? Yes they fit with very very minor rubbing. Although I'm told the 10ply tires are slightly larger but have the same posted dimensions. The 10ply are very stiff tires and I was told by my local tire shop they wouldn't likely wear properly because the Cherokee isn't heavy enough.
I have been running heavy tires on jeeps for years because I have had sidewalls torn out on lighter tires. I was stranded in a remote area of northern Utah because I damaged a second tire before I was able to get the first one replaced. I have not had the problem since I started using the heavier tires. I am undecided on the tires for this jeep as it will be primarily my wife's. I doubt we will get into much more than dirt roads that are not well maintained. Decisions, decisions. I have never had any issues with tires wearing improperly on a light vehicle, they just need proper inflation. Acceleration and mileage certainly do suffer though, which is why I am undecided.
Don_T is offline
post #57 of 90 (permalink) Old 09-17-2016, 08:42 PM
FlyinRob901's Avatar
Thanks @David_Baker for your unnecessary smart *** reply. I posted my experience and you guys seem to find due diligence to give me guilt and blasphemy for trying something new. Way to go. Reminds me why I left this forum in the first place.
Hmm.. I see your problem. Putting spacer above and below the shocks will both lessen the up travel and not improve the height. Though as it would increase down travel you would actually end up with the same total travel just no lift.
Don't take this personally, but if you don't understand how a spring spacer lift works and you 'installed' one that gave you no lift, then yes, you had better wait until an official kit is released and then pay someone to fit it.
Oh wait, 2 kits have already been released and both based on the Aussie spacer lift. Oh and hundreds and hundreds of happy KL owners have fitted them or had them fitted for them.
Mine with the 1 in larger diameter tyres now sits just shy of 2 in above stock.
Oh and post 917 of that same thread is mine before and after the lift.
FlyinRob901 is offline
post #58 of 90 (permalink) Old 09-17-2016, 08:47 PM
And we told you that it's unlikely that you didn't see a change in ride height and that whatever company you went through is wrong. As people say, pictures or it didn't happen.
Xinarin13 likes this.
Len1304 is online now
post #59 of 90 (permalink) Old 09-17-2016, 08:55 PM
Nothing smart *** about my reply, it is purely factual. You yourself stated you put spacers above and below the shocks.
Like I said the first time and I will say it again; if you gained no lift from it you did it wrong. Maybe the company you took it to was right and what you did will not give any lift.
If you would like to post some pics of what you did there will be many on here willing to assist, including me.
post #60 of 90 (permalink) Old 09-17-2016, 09:22 PM
Xinarin13's Avatar
I want someone that knows what they're doing to show a product that's been tested and passed some quality control check. I believe someone telling you to put spacers above and below your shocks is the same as telling someone to put water in their tires to give them more weight/traction in the snow or screwing screws in your tires for better grip on ice...
Look at how your words came across before you complain about how someone else's words come across...
David_Baker likes this.
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is online now
What size winter tire for the TH? BBHawk Wheels, Tires, Brakes, and Suspension 24 10-13-2015 03:06 PM
