Lift Kit & Tire Size Chart - 2014+ Jeep Cherokee Forums
 35Likes
post #1 of 90 (permalink) Old 08-26-2016, 11:52 AM Thread Starter
Hopefully I did this right, but the intent is that this will help current and future members when thinking about lifting the KL. I plan to keep this as a live document and update as more information is available. If you see any discrepancies please let me know and I will make adjustments necessary. I am sure there are some this this one.
I also plan to add maximum tire sizes on each platform so I may need some help with that.
Do you guys think this will benefit this site or is it a lost cause?
taatmk, Rojhan and dhh3 like this.
BLKBEARDRED6 is offline
post #2 of 90 (permalink) Old 08-26-2016, 12:04 PM
Saltybeard's Avatar
It might be beneficial to add the different size tires that people have successfully installed with these lifts and whether griding needs to be done or not. It seems like there are alot of questions and alot of information spread out on the forum.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Saltybeard is offline
post #3 of 90 (permalink) Old 08-26-2016, 12:10 PM
Awesome work, @BLKBEARDRED6. To @Saltybeard's point (what's up with the beards, BTW? ), an additional row or column on stock plus lifted tire sizes would be a great all-in-one reference that could/should be stickied.
Saltybeard likes this.
Rojhan is online now
post #4 of 90 (permalink) Old 08-26-2016, 01:07 PM Thread Starter
Yeah I intent is to add tire sizes. Just didn't have enough time to start that yet.
post #5 of 90 (permalink) Old 08-26-2016, 04:18 PM
HazzardSky's Avatar
Also, my lift is 1.25" front and 1.5" rear. , Not at all 1"
2003 Laredo
Onyx Green | 4.0l i6 | Tow | Selec-Trac |
Mods: 2.5" Hazard Sky Lift | 31" KO2 Tires | Rugged Ridge Diff Covers | Lubelocker Seals | Hitchgate Solo Rear Mount | Led Lighting | Spyder Headlamps | CB/ham | Yakima Rack |
Baltimore, MD
Lift Kit Ordering Info
HazzardSky is offline
post #6 of 90 (permalink) Old 08-26-2016, 04:26 PM Thread Starter
Awesome Thanks for the info. I will adjust.
post #7 of 90 (permalink) Old 08-27-2016, 11:55 AM
This is kind of a corner case, but I recall hearing that those with a winch set up have lost some height in the front (I happen to have a winch set up). If this is true, is it possible to compensate with your kit?
Gary Ray is offline
post #8 of 90 (permalink) Old 08-27-2016, 01:24 PM
HazzardSky's Avatar
It certainly is, but the design on the front of the vehicle means no more than 1.25" of lift is safe, so it will counteract the winch weight if you're not lifted already. If you've already done the full lift, it is what it is at that point.
To level it out and lift it, you could do the full lift in the front and use only one spacer per wheel in the rear. That would give 1.25" in the front and either .4" or .5" in the rear, depending on what size spacer you use/prefer.
Gary Ray likes this.
2003 Laredo
Baltimore, MD
post #9 of 90 (permalink) Old 08-28-2016, 09:09 AM Thread Starter
Sorry guys I haven't had time this weekend to correct the chart. I will get it at work tomorrow.
post #10 of 90 (permalink) Old 08-28-2016, 04:05 PM
myfirstcherokee's Avatar
FWD is confirmed from my Canadian customers
sPod Integration
AirLift Rear Air Suspension
ARB Hidden Compressor
Radar Integration
40 MM Deyeme Racing Spacers
Warn VR8000S Wireless Winch
Klustom Designs 1.5" Lift Kit
myfirstcherokee is offline
Tire size change? indytrucker Wheels, Tires, Brakes, and Suspension 23 09-30-2016 02:06 PM
Tire Size Thekaratekid72 Wheels, Tires, Brakes, and Suspension 4 10-20-2015 04:58 PM
What size winter tire for the TH? BBHawk Wheels, Tires, Brakes, and Suspension 24 10-13-2015 04:06 PM
Hi-Lift Jack size jkolker Wheels, Tires, Brakes, and Suspension 9 06-24-2015 05:35 PM
FWD tire size alanekl Wheels, Tires, Brakes, and Suspension 7 05-20-2015 03:18 PM
