Brake Bleeding Question - 2014+ Jeep Cherokee Forums
 4Likes
  • 1 Post By SS_Syndicate
  • 2 Post By iwfur25
  • 1 Post By jamie1
post #1 of 10 (permalink) Old 09-25-2016, 06:40 PM Thread Starter
Mudman1's Avatar
Hello,
Since I do not have a helper for the project, I picked up a Mityvac MV8000. I have new DOT 3 fluid for the project as well. My question is, does anyone know if I have to do something special with the ABS unit? I have been searching Google and had zero luck. I know to pump the brakes until the pedal feels really firm to depressurize the ABS unit. Is there anything I am missing?
Thanks!
Mudman1 is offline
post #2 of 10 (permalink) Old 09-25-2016, 06:52 PM
sanghill's Avatar
You will probably need a Witech to bleed the ABS unit?
If you do not have air in the brake lines then this is what I do.
Suck the brake fluid out of the resevoir with a baster and needle.
Then you can suck the fluid out of both chambers.
Add clean fluid. You are done.
Let the brake system pump the fluid through the system.
When the fluid in the resevoir looks darker than new fluid then do this again.
Usually I do this about every 6 months. Keeps the fluid fairly clean.
sanghill is offline
post #3 of 10 (permalink) Old 09-25-2016, 06:56 PM Thread Starter
Mudman1's Avatar
Thanks @sanghill. I was reading more and it looks like if I do it the conventional way, ensuring no air gets into the system, I am okay. Then I can take it out for a bit and ensure the ABS has to kick in. For me, I can go up the road, use 4LO and hill descent control, to allow the ABS unit to cycle. Then do a second bleed job. That SHOULD get all the old fluid out and put new fluid in.
I have used the method you described before on some pickup trucks. It is better than nothing for sure! But I want to do this one all the way.
Mudman1 is offline
post #4 of 10 (permalink) Old 09-25-2016, 07:16 PM Thread Starter
Mudman1's Avatar
Here are pictures of my fluid.
ID:	137369   Click image for larger version
Mudman1 is offline
post #5 of 10 (permalink) Old 05-08-2017, 04:04 PM
007
007's Avatar
Yeah, so I was cleaning under the hood today after I changed the oil and decided to check the brake fluid level. That's when I noticed that it's really dark! Pretty much grey looking. Is that normal for out-of-the-factory brake fluid?? I've never seen it that color. I've got about 38,500 miles on her. Needless to say, I'm going to be changing it this weekend.
The BEAST
2014 Cherokee Latitude
Build date: 07/09/2014
In Service Date: 09/02/2014
My purchase date: 7/29/2016
Altitude Pkg
Comfort/Convenience Group
FWD
Uconnect 8.4A
3.2L V6
007 is offline
post #6 of 10 (permalink) Old 05-08-2017, 04:11 PM
SS_Syndicate's Avatar
If you watch the level of the reservoir and keep it above the min line you can bleed without running the ABS/ESC. This said, you would have a small amount of old fluid in that unit until it is activated. For the best bleed it is best to have the unit run which means being controlled by equipment (that to the best of my knowledge) only dealers have.
SS_Syndicate is offline
post #7 of 10 (permalink) Old 05-08-2017, 04:15 PM
Also, many will say that the brake fluid should last the life of the vehicle. I used to agree with this. Then, years ago I had a tow rig that wouldn't stop. I tried everything to improve this, performance pads and rotors, adjusted everything... still it never really improved. Then I had an older guy that I used to hang with in my drag racing days tell me to change the brake fluid. I thought he was full of it, but did it anyway (what did I have to lose?) .... I couldn't believe how much better the braking was! This truck only had 40k miles on it at this time.
007 likes this.
post #8 of 10 (permalink) Old 05-09-2017, 10:05 AM
From spending part of my time in the land of road racing... thank you for recognizing that brake fluid is not forever. I change annually on a track car, 3 - 4 years with good fluid on other cars.
I honestly wouldn't sweat the little bit of fluid that remains in the ABS unit, but if you really want do what you mentioned and activate ABS on a hill or gravel road or something and bleed again. If the Mityvac seems slow or otherwise annoying, consider getting a power bleeder. It puts pressurized fluid (15ish PSI) into the reservoir and out the bleeders, instead of sucking out through them. Pulling from the bleeders tends to suck air in around the threads too, making the process very slow. I usually try to empty the reservoir of old fluid and refill with fresh before starting. Just watch the reservoir. I've seen some actually rise up off the master cylinder. Never had one pop off, but if it does move up I put a zip tie or two around it before pressurizing.
Also I'm kinda OCD and would end up pushing 2 quarts of fluid through with the "bleed, run ABS, bleed again" method to make sure it's very well flushed. But hey it's pretty cheap for something you only do every few years.
Mudman1 and SS_Syndicate like this.
iwfur25 is offline
post #9 of 10 (permalink) Old 05-10-2017, 12:25 AM
jamie1's Avatar
Originally Posted by Mudman1 View Post
Hello,
Thanks!
I really wouldn't worry about the little bit of fluid left in the ABS valve block. Also, so you know, the ABS system does not store any pressure. Pumping the brake pedal with the engine off just depletes the brake booster reserve.
Mudman1 likes this.
jamie1 is offline
post #10 of 10 (permalink) Old 05-10-2017, 01:09 AM Thread Starter
Mudman1's Avatar
I am going to get mine done this summer I guess. $ dried up a bit.
Mudman1 is offline
Parking Brake Question.. JeepMe Wheels, Tires, Brakes, and Suspension 11 10-24-2014 08:41 PM
Brake controller Debbie 2014+ Jeep Cherokee General Discussion 21 10-10-2014 12:11 PM
Question about brake pedal pressure dbfree 2014+ Jeep Cherokee General Discussion 11 09-12-2014 09:22 PM
E brake. What the ??? mtudb24 Engine and Technical Discussion 16 07-21-2014 07:24 PM
