max tire size on trailhawk without lift - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 21 (permalink) Old 02-04-2017, 05:01 PM
Originally Posted by SpeedtekTH View Post
Should, they're only 1/2" taller and 10mm wider tread.
Na they won't. The 245 70 has the wriggled around for the lid to close. The 255 would have the lid lifted slightly.
post #12 of 21 (permalink) Old 02-04-2017, 05:07 PM
Originally Posted by 4x4tographer View Post
I'm running KO2s in 245/70/17 with no lift. No rubbing at all.
My only possible run issue is when I floor it during a turn. The front right tire rubs the lower spring collar (if that's even the right term for it, I'm a novice), but it's a rare occurrence.
It's the small black spot near bottom center.
That should not be the tyre rubbing. The strut and spring base move up and down and turn with the wheel so the distance will never change. More likely a rock or mud or stick or something in the tread hit it.
post #13 of 21 (permalink) Old 02-04-2017, 09:41 PM
SpeedtekTH's Avatar
The 245/70 is also another 1/2" taller again and probably doesn't sit flat in the well causing it to push the lid up.
Pretty sure there was a thread here that said the 255/45 fit.
And also it will probably depend on what tire you are running. A BFG KO2 or a Duratrac have fairly aggressive sidewalls that protrude which could cause interference, My Cooper X/T4's do not and would probably have no issue.
David_Baker likes this.
SpeedtekTH is offline
post #14 of 21 (permalink) Old 02-04-2017, 10:43 PM Thread Starter
Thanks everyone for the info, it's very helpful. Since I have no desire to start trimming on my new jeep I think I'll most likely go with the 265/65/17's.
Pacerized is offline
post #15 of 21 (permalink) Old 02-05-2017, 09:50 AM
4x4tographer's Avatar
Awesome, good to know. Thanks for the insight!
4x4tographer is offline
post #16 of 21 (permalink) Old 02-07-2017, 03:32 PM
edge600's Avatar
I have a 245/75r17 on a stock TH wheel in the spare compartment with the lid flat
fusseli likes this.
edge600 is online now
post #17 of 21 (permalink) Old 02-08-2017, 07:30 PM
totomojo's Avatar
When people say they have no rubbing issues are they checking the tire at full suspension compression?
Also, does this AWD/4WD system require that all tires be the same diameter (i.e. the spare has to match the other tires)?
totomojo is offline
post #18 of 21 (permalink) Old 02-10-2017, 12:46 PM
Didn't you say in another thread that you had to air down to 5psi for that to work? Probably a good piece of information to have in case someone expects to do that without some sort of on board air.
Pitcherman is offline
post #19 of 21 (permalink) Old 02-10-2017, 01:38 PM
edge600's Avatar
Yes I did, and I do keep a small compressor in there with it. Along with a plug kit and tools.
Pitcherman likes this.
post #20 of 21 (permalink) Old 02-13-2017, 05:50 PM
CptCrackers's Avatar
I think I saw in a thread somewhere that the duratrac 245/70/17 will rub ever so slightly on the TH with extreme off Road compression, but that it's not a problem.
For me, it's extremely rare I'd be at that compression. Also, I wonder if airing down a bit prevents it which it seems likely you'd do for that kind of crawling, right?
Sent from my SM-G935T using Tapatalk
CptCrackers is offline
Lift Kit & Tire Size Chart BLKBEARDRED6 Wheels, Tires, Brakes, and Suspension 99 04-14-2017 07:06 PM
max tire pressure lfbar 2014+ Jeep Cherokee General Discussion 28 07-06-2015 04:25 PM
