Steering Noise - 2014+ Jeep Cherokee Forums
post #1 of 3 (permalink) Old 03-17-2017, 01:12 AM Thread Starter
mb1k's Avatar
Steering Noise
Is this the known "steering bushing" moan that requires lubrication of the the two rubber bushings?
https://youtu.be/XOg6chQfBns
2008 Jeep Commander Overland QD II, OME HD suspension, 255 Cooper Discoverer AT3, ARB Simpson III
2016 Jeep Cherokee KL Trailhawk Bone Stock OEM, ARB Simpson III
1966 M416 Project
mb1k is offline
post #2 of 3 (permalink) Old 03-17-2017, 11:05 AM
Sounds more like an outhouse door swinging in the wind
Definitely should be taken to the dealer for warranty work. Evidence is clear; no problem there.
post #3 of 3 (permalink) Old 03-24-2017, 11:55 AM
Mine did that in the cold and then progressively got worse until it was doing it all the time. The dealer replaced both strut top mounts and it fixed the issue. Not sure on cost because it was under warranty.
Pitcherman is offline
Noise when turning your steering wheel? tartagliag Wheels, Tires, Brakes, and Suspension 117 12-25-2016 06:22 PM
Cherokee steering YoBro Wheels, Tires, Brakes, and Suspension 26 01-14-2016 09:09 AM
help with noise coming from behind steering wheel Pal423 Wheels, Tires, Brakes, and Suspension 12 11-20-2014 05:45 PM
Steering wheel making a rubbing noise... MickPA Engine and Technical Discussion 18 02-17-2014 01:43 PM
Steering Noise... Anyone else? Michael 90 Engine and Technical Discussion 2 02-14-2014 04:49 PM
