First Brake Change Questions - 2014+ Jeep Cherokee Forums
post #1 of 13 (permalink) Old 05-09-2017, 03:09 PM Thread Starter
wmoolah's Avatar
Can anyone tell me if I actually need to replace the Brake Caliper Bracket Bolts on my KL. I have seen conflicting information across the forum where some people say that it is a stretch torque type bolt and should be replaced everytime and other DIY brake instructions on our KL do not reference replacing these bolts with brand new bolts when you change the brakes. I am replacing both front and rear on my 2014 Jeep Cherokee Trailhawk V6, Im at 52k miles and do tow somewhat frequently. Needless to say I think these are original brakes and they are gone. I am installing the Powerstop Z23 evolution sport kit K6540 for the front and K6542 in the rear, was able to snag a great deal from advanced auto for 335 for both kits.
If anyone has any advice on the Caliper Bracket Bolts or general brake change advice or can point me in the right direction of a good through DIY on the brakes that would be great.
And does anyone know why the search bar at the top of the forum page has disappeared.
14 Cherokee TH - WM
wmoolah is offline
post #2 of 13 (permalink) Old 05-09-2017, 03:29 PM
That front and rear kit together from amazon was only 230$. Sorry but I can't answer your question in regards to the bolts. I had a shop do mine when I got the z36 kit.
post #3 of 13 (permalink) Old 05-09-2017, 03:37 PM Thread Starter
wmoolah's Avatar
No prob thanks!! yeah amazon didn't have the kit for that one when I looked just them individually and not the Z23 for the front only the Z36, which I don't tow that much to need the 36.
14 Cherokee TH - WM
wmoolah is offline
post #4 of 13 (permalink) Old 05-09-2017, 03:49 PM
This is the part number for the dual piston OE kit KOE6541 and this is the part number for the single piston OE kit KOE6539. Both are available pretty cheap on amazon. Either way, cheaper than the dealer kit. Best of luck finding out about the bolts. I think my kit came with new bolts.
post #5 of 13 (permalink) Old 05-12-2017, 01:20 PM
Desoto's Avatar
Bolts are not required unless worn.
Fj4080 and 007 like this.
Desoto is offline
post #6 of 13 (permalink) Old 05-16-2017, 12:12 AM
fusseli's Avatar
I've never heard of replacing brake bolts, or seen it recommended. I have seen it recommended for suspension bolts but that's different.
fusseli is offline
post #7 of 13 (permalink) Old 05-18-2017, 07:14 PM
Alfrik's Avatar
Did yours come with the calipers, rotors and pads?
Power Stop KC2164A-36 Z36 1-Click Truck and Tow Brake Kit (with Carbon-Ceramic Pads, Drilled and Slotted Rotors and Powder Coated Calipers) https://www.amazon.ca/dp/B01CFL638O/..._jQIhzb0HGEA6D
Alfrik is offline
post #8 of 13 (permalink) Old 05-18-2017, 07:51 PM
I did not get calipers.
This is the kit I got.
https://www.amazon.com/dp/B01E1JTZFG?tag=vglnkc6454-20
post #9 of 13 (permalink) Old 05-18-2017, 07:53 PM
The kit you've linked doesn't say it fits a Cherokee on the powerstop website.
post #10 of 13 (permalink) Old 05-19-2017, 10:01 AM
Alfrik's Avatar
Good catch, thanks. I'm likely going to need pads and at least one new rotor soon. Braking feels like I've got one warping.
Alfrik is offline
"change oil soon" warning 2000 miles after last change hwstock Engine and Technical Discussion 17 03-17-2016 06:37 PM
2 questions sonny_tmcf 2014+ Jeep Cherokee General Discussion 3 01-24-2015 07:14 PM
2 questions sonny_tmcf Interior 6 01-24-2015 07:03 PM
Few Questions irishmark 2014+ Jeep Cherokee General Discussion 6 08-07-2014 05:26 PM
