Will wheel spacers cause more wear on tires and suspension? - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 20 (permalink) Old 05-09-2017, 08:15 PM
Desoto's Avatar
Those retaining bolts are used for the assembly line. As far as wheel spacers, I think they will show some increased Ball Joint wear over time. Too many have failed with no mods at all.
Desoto is offline
post #12 of 20 (permalink) Old 05-09-2017, 08:24 PM
I need to follow-up on that...
I've got 25K miles on the KL and will need to have the second lower ball joint replaced (had the first one done at 20K). And this *damage* only from bad streets, no off-roading or any other abuse. So yeah I can confirm the lower ball joints are weak...
Spacers/adapters add stress to the suspension and steering components connected to the hub, and some vehicules will handle this stress better than others...
post #13 of 20 (permalink) Old 05-09-2017, 08:25 PM
^^ ME... ME-ME !!!...
Ok I wanna start something now...
About that rotor retaining bolt... Since this a spacer/adapter topic, I have to ask... does one really need that bolt ?
The adapter will keep the rotor nice and snug on the hub even when you remove a wheel, because the adapter does a much better job than any retainer bolt... I think...
Ok I'm gone >>>>>>>>>>>>>>>>>>>>>
right, but here's the issue. even with the removal of that bolt, there is still a threaded hole that is too small to let the lug bolt through.
post #14 of 20 (permalink) Old 05-09-2017, 08:33 PM
Touché. Not having removed one yet I didn't picture that. Threads are in the rotor, not in the hub behind ?
Ok then... time to drill those threads out I suppose
post #15 of 20 (permalink) Old 05-09-2017, 09:27 PM Thread Starter
Taf789's Avatar
Yeah maybe I'll just hold off on the spacers for now after reading these posts
Sent from my SM-G920P using Tapatalk
"Obviously, you're not a golfer."
- Dude
2017 Cherokee Latitude V6
Taf789 is offline
post #16 of 20 (permalink) Old 05-10-2017, 09:35 AM
SS_Syndicate's Avatar
@Taf789 A 1" spacer should add the clearance needed for threaded spacer/adapters. This said, I think lug bolts are a PITA to mount the wheel with during a rotation. This also means the wheel is being mounted with aluminum threads versus the steel ones they used to use. Since there are more threads, strength isn't really an issue. However, boogering up a thread is MUCH more likely, especially since the wheel moves around and is only held on be a small hub lip. Switching to a stud and getting lug nuts makes wheel mounting way easier and has stronger threads.
Full disclosure.... I have noticed some vibration on highway speeds acceleration that I can make come and go with having a spacer on versus off. I'm not sure what is going on, but I think there may be a balance issue. I'm still testing different spacers in different spots to see if there is a change.
@Mark_ I kinda agree with you and where you are going with this.... But in the spirit of maintenance down the road, we just prefer the rotor retaining bolt to be left on. If this was the plan I would make sure the adapter/spacer is hub centric though.
My issue is that BORA sells these adapters with an interference issue and they don't even mention what to look for or potential ways to fix it. I suppose the first step though is to acknowledge there is an issue which they have yet to do.
Mark_ likes this.
SS_Syndicate is offline
post #17 of 20 (permalink) Old 05-10-2017, 09:48 AM
After reading everyone else's responses (beyond where I was quoted)... I think most of the "debate" is from old/poor information. What we are talking about are actually adapters. They are bolted onto the hub and then the wheel bolts to the adapter. A spacer is technically a shim that just sits behind the wheel and the original mounting us used. Shim type spacers are very dangerous and are illegal in many places. Adapter type spacers are a totally different thing and I am not aware of any legal issues with using them.
I have ran them on several vehicles and pushed them WAY harder than any road vehicle ever will. I used them in circle and drag race and have ran them on many off-road vehicles. I have seen them fail, but of them, they were cheap foreign made things that were not hub centric and had no annealing or anodizing. Even here, the failures were pulled studs (likely related to over-torquing) and possible with any stud or bolt. I have only seen one crack and it was from being loose.
I read on the interwebs all the time that these are dangerous and that they fail, but these statements are never backed up with real (and personal) experience. It's always a google searched image or an example where all the facts are not known. >>>>>>>>>>> I'll get off my soap box now.
post #18 of 20 (permalink) Old 05-10-2017, 09:53 AM
edge600's Avatar
I wasn't aware when I ordered mine from bora that I could have asked them for pressed in lug bolts, I'm seriously considering ordering new ones just for the aluminum thread issue you mentioned along with being able to throw the wheels onto the bolts then put lug nuts on.
SS_Syndicate likes this.
edge600 is offline
post #19 of 20 (permalink) Old 05-10-2017, 09:57 AM
I understand, and agree on this principle. Keeping it simple. And that, to me, would be to get studded adapters like you've mentionned.
But if I had threaded 3/4" adapters on hand and wanted to use them... I honestly think the easiest and minimally *invasive* method I would pick would be to grind down 4 lug bolts (one per wheel), enough so they don't rest against the rotor retainer bolt. I could buy a few aftermarket bolts to do this, keeping all 20 OEM ones intact. Of course before grinding them down I would thread a 12mm X 1.25 nut onto the bolt first or, better yet, a 12mm X 1.25 threaded die, to fix the thread once the bolt is shortened. I've looked for 20mm shank M12 X 1.25 conical seat bolts (OEM are 27mm) but can't find any right now.
But yeah, studded adapters all the way, when possible.
post #20 of 20 (permalink) Old 05-10-2017, 12:57 PM
Wheyman's Avatar
Not sure how many know this but on the OEM scissor jack there is a mounting stud you thread into a mounting hole in order to rest the wheel on to line it up on the thin hub in order to start the bolts.
Wheyman is offline
2014 Trailhawk Wheel Spacers Mpolizzi Wheels, Tires, Brakes, and Suspension 229 01-12-2017 10:08 AM
Wheel Spacers, Pros and Cons taatmk Wheels, Tires, Brakes, and Suspension 17 07-23-2016 10:19 AM
Wheel Spacers for 2016 Cherokee Latitide? joefish89 Wheels, Tires, Brakes, and Suspension 9 04-23-2016 11:34 PM
NovusTech wheel spacers ptrudel Ontario 0 05-07-2015 04:20 PM
Wheel spacers Rje420247 Owners' Garage 8 06-06-2014 01:34 PM
