Official Alignment Specs - 2014+ Jeep Cherokee Forums
post #1 of 7 (permalink) Old 05-17-2017, 03:42 PM Thread Starter
Does anybody ( @IRSmart ? ) have a reference to the official alignment specs for a '15 TH?
Alignment was done as part of putting on the new KO2s, but I noticed afterward that the alignment detail page shows "Jeep 2014-17 Cherokee 4x4 9/16/2013 - Lifted"
The tire dealer now isn't even sure if that's the right spec, so before I have a do-over, I'd like to know what it's supposed to be.
Rojhan is online now
post #2 of 7 (permalink) Old 05-17-2017, 04:11 PM Thread Starter
Found Wheel alignment specs as one of the first hits on Google, but it's buried in the forum search.
Would be good to verify, though.
post #3 of 7 (permalink) Old 05-17-2017, 05:55 PM
Desoto's Avatar
I posted that a while back. This one is from Mitchell.
Desoto is offline
post #4 of 7 (permalink) Old 05-17-2017, 06:09 PM Thread Starter
Thanks, @Desoto. Interesting to note that doc is for "2014 Jeep Cherokee 3.2L Eng Trailhawk", but it has sections for "FWD","AWD", and "Lifted".
Apparently "Lifted" is the TH.
post #5 of 7 (permalink) Old 05-19-2017, 12:12 AM
Snowhawk2015's Avatar
Correct. All 3 of my alignments (after lift, after bigger tires, after CV replacement) say Jeep 2015 Cherokee 4x4 9/16/2013 - Lifted
9/16/2013 = spec
Lifted = TH
Snowhawk2015 is offline
post #6 of 7 (permalink) Old 05-19-2017, 12:46 AM
fusseli's Avatar
Same one I got too
http://jeepcherokeeclub.com/106-owne...ml#post2541185
fusseli is offline
post #7 of 7 (permalink) Old 05-20-2017, 05:30 PM
For those of you that don't like to do +/- math, here's the tolerance ranges.
Jeep Cherokee 4x4
Specification 9/16/2013 - Lifted (Trailhawk)
Front Wheels
Camber* -0.90° to -0.10°
Caster* +3.80° to +4.70°
Toe 0.00° to +0.10°
Total Toe** 0.00° to +0.20°
Steer Ahead -0.05° to +0.05°
Rear Wheels
Camber* -1.40° to -0.60°
Toe -0.08° to +0.08°
Total Toe** -0.15° to +0.15°
Thrust Angle -0.10° to +0.10°
Notes:
* For reference only (nonadjustable angles).
** Total Toe is the sum of both the left and right wheel toe settings. It should be equally split between each wheel on the same axle to ensure the steering wheel is centered after adjusting the toe. Also see Steer Ahead. Positive toe (+) is toe in. Negative toe (-) is toe out.
*** Toe and Total Toe may be listed in inches depending on the alignment equipment.
Front Wheels
Toe 0" to +3/64"
Total Toe 0" to +3/32"
Rear Wheels
Toe -1/32" to +1/32"
Total Toe -5/64" to +5/64"
Wiper alignment MarkS49675 Exterior 1 04-21-2016 10:41 AM
Wheel alignment specs rfsod48 Wheels, Tires, Brakes, and Suspension 7 04-19-2016 11:51 AM
Wheel alignment specs David_Baker Wheels, Tires, Brakes, and Suspension 6 11-12-2015 10:52 AM
Wheel Alignment uhdpham Wheels, Tires, Brakes, and Suspension 6 06-04-2015 09:48 AM
Alignment issues sfdxsm Wheels, Tires, Brakes, and Suspension 19 03-02-2015 03:26 PM
