TPMS on spare - 2014+ Jeep Cherokee Forums
 7Likes
post #1 of 28 (permalink) Old 06-16-2017, 04:45 PM Thread Starter
TPMS on spare
Did anybody's spare come with TPMS or have you added TPMS?
I got my used TH rim to put on the spare so I can do 5-wheel rotation. The tire shop said that since the spare didn't come with a TPMS sensor, that it wouldn't be able to recognize it if it was added.
Anybody know the specific of if/how this will/won't work?
The wheel wasn't pristine, but it was in really good condition. I probably have some similar scuffing on the original wheels.
Now I need to find a center cap...
Thanks!
Rojhan is offline
post #2 of 28 (permalink) Old 06-16-2017, 04:57 PM Thread Starter
According to this thread, it looks like I can just add a sensor and have it work once it's in an active position?
No TPMS on spare tire/wheel
Rojhan is offline
post #3 of 28 (permalink) Old 06-16-2017, 05:36 PM
only question would be, will the car "see" the fifth sensor in the trunk and get confused, or possibly misrepresent the tire pressure. the sensors themselves are very inexpensive in these cars, less than $20 last i checked.
post #4 of 28 (permalink) Old 06-16-2017, 05:42 PM Thread Starter
I thought the tire had to be rotating before the TPMS sensor itself would activate. Then it's the closest sensor/close-enough that gets read.
TopGunKovac likes this.
Rojhan is offline
post #5 of 28 (permalink) Old 06-16-2017, 06:22 PM
you mean the sensors inside the tires need to be rotating? no, or else the readings wouldn't change when you're stationary and airing back up.
post #6 of 28 (permalink) Old 06-16-2017, 09:19 PM
I thought it took a while for the new pressure to hit the EVIC for the exact reason that it had to run a bit?
post #7 of 28 (permalink) Old 06-16-2017, 09:29 PM Thread Starter
It looks like the TPMS sensors can be tickled awake by the car meaning they are probably asleep when the ignition is off.
Tomorrow is scheduled maintenance. I'll ask about it.
Rojhan is offline
post #8 of 28 (permalink) Old 06-16-2017, 09:52 PM
.... The tire shop said that since the spare didn't come with a TPMS sensor, that it wouldn't be able to recognize it if it was added. Anybody know the specific of if/how this will/won't work?
Thought I remembered reading this in the user's manual (This is for the 'Premium 'TPMS system):
Vehicles With Matching Full-Size Spare
1. The matching full size spare wheel and tire assembly
has a tire pressure monitoring sensor that can be
monitored by the TPMS.
2. If you install the full size spare in place of a road tire
that has a pressure below the low-pressure warning
limit, a chime will sound and the “TPMS Telltale
Light” will turn on upon the next ignition key cycle. In
addition, the EVIC/DID will display a Tire Low
message, an #Inflate to XX# message and a graphic
showing the low tire pressure value in a different
color.
3. After driving the vehicle for up to 20 minutes above
15.5 mph (25 km/h)
the “TPMS Telltale Light” will
turn OFF, as long as no tire pressure is below the
low-pressure warning limit in any of the four active
road tires.
4. The EVIC/DID will display a graphic showing the tire
pressure value in the same color as the other pressure
values in place of the different color low tire pressure
value. The EVIC/DID will also display a “SPARE
LOW PRESSURE” message to remind you to service
the flat tire
post #9 of 28 (permalink) Old 06-16-2017, 11:56 PM
That is incorrect, the spare has no TPMS sensor of any kind.
LeoKnightas likes this.
post #10 of 28 (permalink) Old 06-17-2017, 04:42 AM
airishfan's Avatar
i don't think it would read the 5th one in the trunk because when i got a flat and used my spare it did not read the tire with the TPMS sensor it just showed 3 and said the one was missing
airishfan is offline
Tpms teo 2014+ Jeep Cherokee General Discussion 5 11-24-2015 10:51 PM
Tpms Shelly Wheels, Tires, Brakes, and Suspension 10 11-14-2015 12:14 PM
TPMS Sensors. To get or not to get? DurhamTrailhawk Wheels, Tires, Brakes, and Suspension 26 01-07-2015 12:47 PM
No TPMS on spare tire/wheel PCRit Wheels, Tires, Brakes, and Suspension 39 09-11-2014 03:17 PM
Tpms va3rbz Electronics, Audio, and Lighting 4 01-03-2014 11:53 PM
