2014 cherokee trailhawk wheel/tire fittment - Page 3 - 2014+ Jeep Cherokee Forums
 9Likes
post #21 of 50 (permalink) Old 03-19-2015, 02:40 PM
NicTopsider's Avatar
I'm looking to put BF Goodrich MTs on my Trailhawk.
I'm wondering what width I should go with/would be able to do on the stock rims.
Currently the stock Firestones are 245/65/17,
Wondering if I could pull off a 245/70/17 or even a 245/75/17 size tire. Thoughts guys?
Papa-Hells likes this.
Nic Topsider
2015 Trailhawk "Tombstone"
- Black, Black, and Black
NicTopsider is offline
post #22 of 50 (permalink) Old 03-19-2015, 10:55 PM
cherokeeyeah's Avatar
245/70/17 you could do and some already have, I and others have wondered about 255/60/17's. This site can help you get size ideas.
http://tire-size-conversion.com/tire-size-calculator/
cherokeeyeah is offline
post #23 of 50 (permalink) Old 03-20-2015, 03:23 AM
Papa-Hells's Avatar
Originally Posted by nictopsider View Post
i'm looking to put bf goodrich mts on my trailhawk.
I'm wondering what width i should go with/would be able to do on the stock rims.
Currently the stock firestones are 245/65/17,
wondering if i could pull off a 245/70/17 or even a 245/75/17 size tire. Thoughts guys?
^^^^^this^^^^
Papa-Hells is offline
post #24 of 50 (permalink) Old 03-20-2015, 09:26 AM
zzjdzz's Avatar
Interested in results, I will most likely be putting a 245/70/17 on my TH wheels for regular conditions and 265/75/16 for my off road set, with spacers
zzjdzz is offline
post #25 of 50 (permalink) Old 03-20-2015, 11:25 AM
We have spacers for the Dart, which also fit the Cherokee, from 6mm (1/4") all the way to 19mm (3/4"). The 19s are hub-centric on both sides, so there's a 65.1mm lip on the wheel side to make wheel install easier. They also all come with longer lug bolts, so you don't have to seach elsewhere for them. MyFirstCherokee is in the process of installing our 40mm wheel adapter kit, and should be posting pics of that soon. With all those spacing options, it should open up the wheel availability quite a bit.
mtudb24 likes this.
DeyemeRacing is offline
post #26 of 50 (permalink) Old 03-22-2015, 09:32 AM
Jaro360's Avatar
16's won't fit over the brake calipers. The smallest size they have on base cherokee's is 17's. 245/70/17 is what I'm interested in with the right amount of back spacing to on the wheels to prevent rubbing. Possibly go slight wider on the tire with enough back spacing.
__________________
Trailhawk
Bright White
Hood Decal
3.2 V6
Trailer Tow Pkg
Comfort/Convenience Group
Jaro360 is offline
post #27 of 50 (permalink) Old 03-22-2015, 11:23 AM
hwstock's Avatar
I don't think the rim diameter makes much difference beyond 17". A friend has a wrangler with 255/75/17.
I guess I'm curious what the OP meant by "beefing up."
The stock destination ats have wider tread area, even though they have the same specs as most 245/65/17 tires.
The stardard destination a/ts are P-rated, I believe the equivalent of 4-ply (no one really uses plies anymore, but the "ply-equivalent" is now in our lingo). Even the upgrade wrangler tires are no more than 6-ply. Some would say these are still "street tires."
I have dueler 2 245/70/17 A/T L-rated (10-ply equivalent) because I live in an area with lots of sharp rocks, and want to avoid sidewall punctures. They are a bit wider and 1/2 inch in radius larger than the stock, which gives me near 1/2 inch more clearance. They make the vehicle drive a bit more like a truck, and reduce the mileage about 1 mpg. However, the actual tread width is about the same as on the stock tires. No rubbing.
If yo get really big tires, they won't fit in the spare wheel well. My new 245/70/17s barely fit, and I certainly notice the weight difference when I change a tire and throw the spare in the back.
The trailhawk has lug bolts, not lug nuts, and that results in different strategies when you change tires.
hwstock is offline
post #28 of 50 (permalink) Old 03-22-2015, 12:21 PM
zzjdzz's Avatar
zzjdzz is offline
post #29 of 50 (permalink) Old 03-22-2015, 09:33 PM
mtudb24's Avatar
so what spacers will work with Stock TH rims and oversize 245x70x17 tires? Seems like if I move the wheel out of the wheel well (offset it to the outside), wouldn't the outside edge of the tread rub the rear portion of the wheel well during turning?
2014 Trailhawk. Bright White exterior. Black Leather interior. V6. All available options (Cold Weather, Comfort / Convience, Sunroof, tow package, hood decal, Nav radio, 9 speaker sound system) , 245/70/17 Firestone Mud Terrains, BVG roof rack, LED fog lamps, LED interior lamps, LED back up bulbs, hood decal pinstripe, rear mounted hitch tire carrier, AFE Cold Air Intake
mtudb24 is offline
post #30 of 50 (permalink) Old 03-23-2015, 09:19 AM
zzjdzz's Avatar
Unfortunately a spacer will not help a stock wheel with a 245/70/17 from rubbing. The spacer does not decrease the diameter of the tire. The spacer I will be installing will be so that I can install a 16" wheel and clear the brake caliper. I will then have an extra inch (theoretically) to add more tire. The rubbing that comes from a 245/70/17 on a stock wheel, I am ok with.
zzjdzz is offline
My new wheel and tire combo for winter priell3 Wheels, Tires, Brakes, and Suspension 12 05-20-2014 09:11 AM
Trailhawk Wheel/Tire Questions frobert775 Wheels, Tires, Brakes, and Suspension 4 03-29-2014 08:54 PM
My Wheel and Tire ideas Tyler-98-W68 Wheels, Tires, Brakes, and Suspension 19 02-06-2014 11:01 PM
Want To Buy (1) 17" Latitude Wheel or Wheel/Tire BabyGrand Cherokee (KL) Parts & Accessories 0 01-26-2014 12:10 PM
Just about time for a wheel and/or tire thread sticky? bruceg Wheels, Tires, Brakes, and Suspension 3 01-15-2014 10:48 AM
