2014 cherokee trailhawk wheel/tire fittment - 2014+ Jeep Cherokee Forums
 9Likes
post #1 of 50 (permalink) Old 05-24-2014, 04:35 PM Thread Starter
new here..
I am thinking about beefing up my 2014 Cherokee Trailhawk to 18"
wheels and tires..
I understand the bolt pattern is 5 x 110 and the offset is 45 ( for the 18" )
please correct me if I am mistaken..
the tires I want to be bit beefier as the 17"s are a bit whimpy..
has anyone successfully put 18" wheels and tires on without them rubbing ?
thanks
mike
DevilHawk42 likes this.
bighouses is offline
post #2 of 50 (permalink) Old 05-24-2014, 06:58 PM
That depends on the size of the tire you will be running. Lots of sizes in an 18 inch tire. The stock limited wheels are 18inch so it is possible.
John
Hudsonhawk is offline
post #3 of 50 (permalink) Old 05-24-2014, 07:37 PM
RojStock's Avatar
Rim size matters but it's the combination of Tire wall size and rim that makes the overall diameter. You can have 18's with low profile tires be smaller then 17's, the Cherokee being a prime example. 18's on the limited are smaller diameter then the 17's on the TH.
Check out the Goodyear Duratec thread and see tires on the 17" wheels rubbing. Basically it is the maxed out size you can go.
RojStock is online now
post #4 of 50 (permalink) Old 05-24-2014, 11:27 PM
Bondo's Avatar
Location: Central Valley, Peoples Republic of Kalifornia
I remember the days when we ran 15" wheels and bead locks on the rubicon trail.
Papa-Hells likes this.
2014 Granite Trailhawk
Misplaced Texan caught behind enemy lines in the PRK.
Bondo is offline
post #5 of 50 (permalink) Old 05-28-2014, 08:32 AM
I went from the stock 17's to the limited size 18's without issues.
Just go to tirerack and select the limited in your vehicle options, it will list all 18's that fit a KL.
3wheelerdude is offline
post #6 of 50 (permalink) Old 05-28-2014, 10:31 PM Thread Starter
trailhawk wheel fittment
thanks mate it seems the offset of the wheel is now going to be the issue..
the 17's are 17 x 7 with 5-110 bolt pattern with a 31 offset
the 18's are 18 x 7 1/2 with 5-110 bolt pattern and a 45 offset.
hard to find wheels with similar characteristics..
post #7 of 50 (permalink) Old 05-29-2014, 08:36 AM
Enkei M52. That's what is on mine. I will post pics once I get time to wash the darn thing!
zzjdzz likes this.
post #8 of 50 (permalink) Old 05-29-2014, 12:58 PM
This change in offset and wheel width will only move the rim forward. You get the same clearance at the back of the wheel (which is important) and a wider tire that extends outwards.
Should be no problems.
Cherokee-Gym is offline
post #9 of 50 (permalink) Old 05-29-2014, 01:19 PM
dawhitesTH's Avatar
those are almost identical in backspacing. "The offset doesn't have to match the OE offset exactly, but it needs to be within a reasonable range and must clear the suspension. Keep in mind that because offset is measured from the wheel's centerline, a 7" wide wheel with 40mm offset will fit differently than a 7.5" wheel with the same offset." You should be fine with either one. Just be careful with the aspect ratio of the tires for the 18's. the bolt pattern for the trailhawk Wheel is 5x110 offset of +42.
dawhitesTH is offline
post #10 of 50 (permalink) Old 06-06-2014, 02:41 PM
awd_mike's Avatar
new here..
wheels and tires..
thanks
mike
I'll buy your TH wheels from you if you want to sell.
2014 Cherokee Sport
4X4 I4/ Winter Pkg. / Rear Camera / Roof Rails / North Wheels
Black on Black
awd_mike is offline
My new wheel and tire combo for winter priell3 Wheels, Tires, Brakes, and Suspension 12 05-20-2014 09:11 AM
Trailhawk Wheel/Tire Questions frobert775 Wheels, Tires, Brakes, and Suspension 4 03-29-2014 08:54 PM
My Wheel and Tire ideas Tyler-98-W68 Wheels, Tires, Brakes, and Suspension 19 02-06-2014 11:01 PM
Want To Buy (1) 17" Latitude Wheel or Wheel/Tire BabyGrand Cherokee (KL) Parts & Accessories 0 01-26-2014 12:10 PM
Just about time for a wheel and/or tire thread sticky? bruceg Wheels, Tires, Brakes, and Suspension 3 01-15-2014 10:48 AM
