Headlight washers - 2014+ Jeep Cherokee Forums
 12Likes
  • 5 Post By myfirstcherokee
  • 4 Post By gravitywell
  • 1 Post By ptrudel
  • 2 Post By David_Baker
post #1 of 7 (permalink) Old 02-24-2016, 10:19 PM Thread Starter
myfirstcherokee's Avatar
Headlight washers
I have been toying with this idea for awhile now. Whats to say we don't incorporate these ourselves over here in the states? We could make a how to, find the best option for the actual nozzle, even investigate if there is enough room to have a hidden pop up with spray activation, and have it linked with the windshield washers. Who thinks we can achieve this?
SkipW, TedB, ptrudel and 2 others like this.
sPod Integration
AirLift Rear Air Suspension
ARB Hidden Compressor
Radar Integration
40 MM Deyeme Racing Spacers
Warn VR8000S Wireless Winch
Klustom Designs 1.5" Lift Kit
myfirstcherokee is online now
post #2 of 7 (permalink) Old 02-24-2016, 11:58 PM
I also want our overseas brethren's power folding mirrors.
post #3 of 7 (permalink) Old 02-25-2016, 12:19 PM
ptrudel's Avatar
Windshield spray nozzles should have been a must with this headlight design. Almost needs its own pump though, just because the lights need washed, doesn't mean you need the wipers going at the same time, but then that's just getting complicated.
A low profile washer nozzle would do the same, no real need for a pop up, although, that would be slick.
UN4GTBL likes this.
ptrudel is offline
post #4 of 7 (permalink) Old 02-25-2016, 12:27 PM
It would complicate the bumper removal by a little bit. Personally I haven't had a problem with my lights being too dirty. I personally want the heated washers or even heated headlight nossles before basic ones. I hate storm chasing in a blizzard and everything freezes up and now I can take care of road spray.
post #5 of 7 (permalink) Old 02-25-2016, 12:36 PM
Warloq's Avatar
Thanks ptrudel - give me access and then trump me. :-)
I've been toying with drawing this one up -- just a T line off of the existing washer tank (it's pretty big) and a separate motor to drive two sprayers - power rinse effectively. Initial look is that there is room for a line and mounting of the sprayer. I'm unfamiliar with the mechanics of a pop-up, but would also question the need for that extra complexity. I also don't see need to tie them in into existing wipers -- maybe the 'spray' relay only, but I think just another switch would be easier. Realistically the main use will be for bug splats, ice or dust on dirt roads... windshield is affected by those differently, so I see spraying at diff times. Irun the de-icer additive in my main tank, so using that for headlights in winter should also work. The factory spray heads on my TH hood put out a good amount and a nice pattern, so I'm looking at them - they spread early, in a nive upward/V patern, so if I get them just enough forward of the light I think they'll put a good spread on there - def enough to rinse the lenses. What I have not been able to figure, without some serious work, would be how to mount actual mini-wipers like some cars have, or if those would even be practical with the shape of our lenses.
2015 Trailhawk
Warloq is offline
post #6 of 7 (permalink) Old 02-25-2016, 07:03 PM Thread Starter
I think the lenses of the cars that had those wipers were made of glass. With ours, the wipers could eventually create rub marks and scratches.
The pop up designs were always actuated via the flow of fluid through them. That wouldn't be a problems here.
Heated would work well if we had the Mopar accessory for heated windshield sprayers. I think it's $150, plug and play.
Would definitely need a low profile one since light output already is bad even with drop in kits. Hence the reason I suggested pop up designs. But if we can use the factory washers there as well, it would be a true oem configuration. Even if we used oem tubes! Lol
post #7 of 7 (permalink) Old 02-25-2016, 10:33 PM
Ours with the washers work like this. We have a separate motor in the washer bottle and if the headlights are on when the windscreen is washed it squirts the headlights 2 or 3 times.
UN4GTBL and madchemist24 like this.
Led HeadLight Beam Pattern/Projector Headlight ironsied Electronics, Audio, and Lighting 0 11-28-2015 08:52 PM
Headlamp washers/spray. Jeepn3wbie Exterior 25 08-18-2015 11:34 AM
headlight # DL # ak4wheel Electronics, Audio, and Lighting 43 12-02-2014 01:44 PM
Headlight Help. jernbec924 Electronics, Audio, and Lighting 0 10-17-2014 02:52 PM
We didn't want headlight washers and cool front fascia. gsxr150 2014+ Jeep Cherokee General Discussion 19 06-27-2014 11:29 PM
You may not post new threads
You may not post replies
