Front Tow Hooks for Non-TH - 2014+ Jeep Cherokee Forums
 12Likes
  • 3 Post By AGP
  • 8 Post By AGP
  • 1 Post By ptrudel
post #1 of 8 (permalink) Old 02-26-2016, 09:51 AM Thread Starter
AGP
AGP's Avatar
Very simple mod for non-th's, will be stealth (hidden under front fascia)
2-10,000LB tow hooks that can be bought anywhere really (Princesauto, canadian tire or Equivilent)
Painted Red with matte clear coat
2x 3.5" x 1/2" class 8 bolts
Will install them tonight after work and post pictures
DRILLING REQUIRED.
ptrudel, zak0902 and CherokeeFred like this.
----- Silver 2015 Cherokee North 2.4L i4 4x4 AD1 -----
-80,000 KM (50,000 Miles)
-0W-20 Quakerstate Full Syth + K&N Filter
-1 1/8" Suspension Lift
-245/70R17 GENERAL GRABBER AT2 Tires
-Resonator Delete + Thrush Glasspack Muffler + 3.5" Chrome Tip
-Custom Roof rails and Rack w/ Tire mount & Fairing
-4x 6" PILOT Halogen Lights
-2x 4" Light Bars
-2x 10,000LB custom Tow Hooks
-Black Plasti-Dip'd Badges and Window trim
-1500W K40 4' CB antenna + Uniden Pro505
-Custom Ladder
AGP is offline
post #2 of 8 (permalink) Old 02-27-2016, 04:01 PM Thread Starter
AGP
AGP's Avatar
Update:
Install time: ~1 Hour
Result: Very stealthy tow hook that can't be seen unless you are under the car.
Painted (original is black)
Before instalation
Cover removed
Aluminium frame
1/2" holes drilled
Installation with 1/4" spacer between hook and frame
Cover re-installed, cut cover around hook (easy to cut since its like cardboard)
After installation
-2x 4" Light Bars
-Custom Ladder
AGP is offline
post #3 of 8 (permalink) Old 02-29-2016, 08:50 AM
How did you get the nuts inside the frame rails? Or did you just thread the holes?
John
Hudsonhawk is offline
post #4 of 8 (permalink) Old 02-29-2016, 08:56 AM
ptrudel's Avatar
Good job! You'll be getting asked for some DIY instructions for sure, lots of members will want to do this.
AGP likes this.
ptrudel is offline
post #5 of 8 (permalink) Old 02-29-2016, 09:19 AM
Banned
He may have drilled all the way through to the top of that rail, and put the nut on the top.
myfirstcherokee is offline
post #6 of 8 (permalink) Old 02-29-2016, 11:30 AM Thread Starter
AGP
AGP's Avatar
First is right, drilled 1/2" all the way through and put nuts at the top.
3 1/2" bolts are just long enough to get the last threads on the bolt so washers wont fit unless you remove the 1/4" spacer that I put in.
AGP is offline
post #7 of 8 (permalink) Old 03-04-2016, 01:21 PM
Warloq's Avatar
I can't quite tell from head on pic, but it looks like you are giving up about an inch on max approach versus original plastic/covers? Not sure that would really bug me, as alternative was no hard-points, just looking for get a bit of perspective on what folks could expect in brush country in terms of knowing how deep they can be till they need to begin thinking about accidently hooking stuff and needing to check/clean those once they get going forward again... Great adaptation though!
2015 Trailhawk
Warloq is offline
post #8 of 8 (permalink) Old 03-05-2016, 01:41 PM Thread Starter
AGP
AGP's Avatar
Bigger tires and a lift would fix that :P
-2x 4" Light Bars
-Custom Ladder
AGP is offline
Front tow hooks Ajalfano Exterior 24 04-26-2016 04:45 PM
Adding front tow hooks Unicorn1 Owners' Garage 18 11-23-2015 09:11 AM
Jeep : Grand Cherokee LAREDO LAREDO SUV 4.0L CD 4X4 Tow Hooks Tires - Front All-Seaso Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 04-23-2014 02:00 PM
TH front tow hooks rvmarc Cherokee (KL) Parts & Accessories 2 04-02-2014 01:12 AM
You may not post new threads
You may not post replies
