Adjustable Sway Bar End Links with Quick Disconnect - Page 8 - 2014+ Jeep Cherokee Forums
 71Likes
post #71 of 77 (permalink) Old 08-03-2016, 07:00 PM
I guess it also depends how stiff the sway bar is. A largeish range ranger that is probably set up mostly for road driving probably has a quite stiff sway bar and could really benefit from releasing it. Easy test is to hang it diagonally in a ditch and see if the suspension reaches full compression and full droop at the same time. If not or is only just then definitely an advantage.
Either way would most likely make off road driving much smoother - that was one thing I found on my Wrangler.
post #72 of 77 (permalink) Old 08-03-2016, 07:41 PM
I have a place I can test mine. Who wants to come over and test it.
David_Baker likes this.
post #73 of 77 (permalink) Old 08-03-2016, 10:37 PM
Tyler-98-W68's Avatar
Originally Posted by myfirstcherokee View Post
So after checking out a very intriguing video from Top Gear, Season 20, Episode 6, we see that with Range Rover, they have IFS on their flagship SUV. On top of this, they have the ability to disconnect their sway bars electronically as well to give better articulation. This is the same process of the end links. So coming from an engineers thought process of a $100,000 SUV, disconnecting the links from the sway bar must be beneficial on an IFS platform
As I posted earlier there is absolutely a benefit from having the swaybar disconnected, I won't be taking my swaybars off yet.
On the Jeep Patriot board one member modified JK quick remove swaybar links to work on a patriot. He measured the angles and found there were 1 degree away from being out of factory tolerances. Regardless of whether they were out of factory tolerances or not on that platform the CV's got eaten alive. That's the only reason I have concern with doing this on this platform.
Comparing CV axles though, it appears the Cherokee has pretty robust CV's compared to my old Compass
Compass
ADII Limited
Bigger is better right
One other thing to note. On my Compass, when the front swaybar was disconnected I had binding on the strut on the driver's side and binding on the lower control arm on the passenger side, whenever either side was at full drop.
Passenger side
This may have been because the CV axles were different sizes on each side, not sure if the Cherokee is like that.
The rear swaybar was unable to be disconnected on my Compass because the actual swaybar would bind on the rear axles. The only way to fix the problem was cut the swaybar out and you couldn't just remove it without dropping the rear diff. The Cherokee design in the rear doesn't have this problem.
Either way I know I'm not comparing apples to oranges but there may be clearance issues if the swaybar is disconnected. I know on my Compass there is no way Jeep would have ever thought someone would run them with the swaybar disconnected and its quite possible on the KL platform there might be issues.
Can't wait to see someone else sacrifice their KL for the community. I wrecked my previous Compass doing the same
2016 Cherokee Trailhawk V6
Rhino
AFE Intake
Flowmaster Super 10 Muffler
Noco Onboard Charger
Trailer Tow
Sunroof
Nav & 9 Amplified Speakers
White
TH Wheels
Trailer Tow
Luxury Package
Technology Package
Sunroof
LED Fog Lights
Tyler-98-W68 is offline
post #74 of 77 (permalink) Old 08-03-2016, 10:41 PM Thread Starter
myfirstcherokee's Avatar
Thank you for the positive contribution. Have to consider the lower control arm hitting the sway bar during tuck
sPod Integration
AirLift Rear Air Suspension
ARB Hidden Compressor
Radar Integration
40 MM Deyeme Racing Spacers
Warn VR8000S Wireless Winch
Klustom Designs 1.5" Lift Kit
myfirstcherokee is offline
post #75 of 77 (permalink) Old 08-12-2016, 01:36 AM Thread Starter
Goal is to offer in color matched design. I have mango tango, silver. And cherry red so far. Here is the design for those who were skeptical if they would exist. MFC Offroad exclusive.
Mango Tango pictured.
David_Baker and 11bmopar like this.
sPod Integration
Radar Integration
post #76 of 77 (permalink) Old 08-12-2016, 05:42 AM
Looks good. So how do you use them? I can see what looks like a quick disconnect at the top and a bolt on the bottom. Do you disconnect one end and leave the other attached? If so how do you secure it to stop it getting in the way or hitting other bits while driving?
Still trying to work in my head how you would get to them without removing the wheel or lying on the ground and sliding under though.
post #77 of 77 (permalink) Old 08-12-2016, 08:01 AM Thread Starter
When you turn the wheel you can access the location with arm while standing adjacent to wheel. There is a clip that is part of the kit that will hold it in place
sPod Integration
Radar Integration
Front Sway Bar Disconnect henry2513 Wheels, Tires, Brakes, and Suspension 7 06-03-2016 05:35 PM
Sway Bar Disconnect?? Meeko 2014+ Jeep Cherokee General Discussion 2 02-11-2016 04:04 PM
Sway bar links Backwoods Raider Off-Road 3 12-19-2015 09:50 AM
Sway Bar Disconnect zzjdzz Off-Road 12 05-01-2015 12:32 PM
You may not post new threads
You may not post replies
