RRO Bumper Info Pease - Page 2 - 2014+ Jeep Cherokee Forums
 4Likes
post #11 of 20 (permalink) Old 03-22-2017, 07:59 AM
Every time I see a picture of a KL with this bumper I want one and then I read about RRO's quality control with almost every unit and I put my wallet back in my pocket. I still can't believe these guys are the only game in town for this type of stuff on the KL.
stl14klhawk likes this.
Pitcherman is offline
post #12 of 20 (permalink) Old 03-22-2017, 08:56 AM Thread Starter
SS_Syndicate's Avatar
Prior to signing up here, I had no experience with RRO. I'll admit I didn't research much in the way of reviews before our purchase either. Don't get me wrong, I had read some, but buried my head in the sand a bit to it being a real issue. It is my understanding that there will soon be some other options. I tried VERY hard to get a few other armor/bumper fabricators interested, but they declined. I even considered making my own, but with so many other projects going, a family, job, and website... I "thought" I was saving some time and effort by going ahead with this purchase.
SS_Syndicate is offline
post #13 of 20 (permalink) Old 03-22-2017, 09:04 AM
I installed the RRO bumper with the recommended Warn winch on my wife's TH. I had to grind a lot off the two welded nuts on the driver's side just to get the winch to fit the mounting holes and clear the AC. I also have the gaps between the front plate and the factory bumper. I have about 3/4" on the passenger side and 1/2" on the driver's side. I was going to pull it apart and cut the spacers and bolts but she said it looks OK as it is so I didn't. I may fix it some day but no hurry as I have plenty of other things to do.
SS_Syndicate likes this.
2017 Trailhawk
Don_T is offline
post #14 of 20 (permalink) Old 03-22-2017, 04:38 PM
Pondhopper's Avatar
Is it that the spacers are wrong or is it that the space varies from Jeep to Jeep. if it is a fixed space what size should it be?
Pondhopper is offline
post #15 of 20 (permalink) Old 03-22-2017, 05:02 PM Thread Starter
I HIGHLY doubt this variance on the Jeep. It's much more likely it's a combination of the inner bumper structure and spacer length. The bottom line is I could see every one needing to be a bit different.
post #16 of 20 (permalink) Old 03-22-2017, 05:14 PM
Pondhopper's Avatar
Can the original hook bolts still be used for the hooks are do you have to use new ones due to a change in length?
post #17 of 20 (permalink) Old 03-22-2017, 05:18 PM Thread Starter
The old bolts threaded into a part that stays on the old structure that is removed. They would be a bit too long, but the bigger issue was me not having a nut to go on the metric bolt. Since a run to the hardware store was needed anyway, I just got grade 8 standard bolts that were the correct length.
post #18 of 20 (permalink) Old 03-22-2017, 05:22 PM
Pondhopper's Avatar
just checking thanks
post #19 of 20 (permalink) Old 03-22-2017, 06:35 PM
Xinarin13's Avatar
Originally Posted by Alfrik View Post
Ugh, now I'm sort of worried about doing my install. I can't imagine how they could get the build that bad. Well, unless their jig/tool/dies are worn.
They regularly get many things this wrong and some even worse.
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is offline
post #20 of 20 (permalink) Old 03-23-2017, 12:19 PM
Alfrik's Avatar
The sliders were in good condition, and fit. However, I've noticed one end seems to have been ground or dragged after the finish was put on. I'm going to get them recoated.
Alfrik is offline
Those with the RRO bumper: will these fit? IRSmart Electronics, Audio, and Lighting 8 01-21-2017 11:31 AM
RRO bumper questions IRSmart Exterior 4 01-04-2017 08:39 AM
SOLD
RRO Combo Bumper Set
Ghost202 Cherokee (KL) Parts & Accessories 6 12-06-2016 05:52 PM
Bumper bar / supersliders besides RRO? skuzzzzy Exterior 17 06-15-2016 10:49 PM
RRO Bumper Fitting questions thebigler Exterior 7 04-29-2015 10:36 AM
