RRO non slider rock rails - 2014+ Jeep Cherokee Forums
 9Likes
  • 1 Post By jkolker
  • 1 Post By RojStock
  • 3 Post By RojStock
  • 4 Post By clew
post #1 of 8 (permalink) Old 09-02-2014, 09:39 PM Thread Starter
gundad's Avatar
Has anyone tried the regular rock rails from Rocky-Road? I've seen a few threads about the sliders but not the plain ones. Are they really a direct bolt on with no drilling?
The fox knows many things but the hedgehog knows one great truth.
gundad is offline
post #2 of 8 (permalink) Old 09-02-2014, 10:31 PM
I'd be interested to hear also. I like the price of the regular rock rails from Rocky-Road, even if I pay someone to fit them they'll still come in well below the Mopar equivalent. It really beats me why Chrysler couldn't have fitted rock rails with the TH off-road package and feel that without them the 'Trail Rating' is a little weak.
Newislander is offline
post #3 of 8 (permalink) Old 09-02-2014, 11:02 PM
jkolker's Avatar
I was under the impression that the standard rails are identical except for the "step"
From their website describing the steprail:
Each Steprail kit mounts identical to the standard Rock Slider for the vehicle. It also still features that great looking 45* front and rear edge. This is basically the same proven design as our world famous Rockrails, only with the extra slider tube up top.
gundad likes this.
2014 Cherokee Trailhawk - V6 - Deep Cherry Red - Options - All
Ordered 10/11/13, Received 12/9/13
jkolker is offline
post #4 of 8 (permalink) Old 09-03-2014, 01:03 AM
RojStock's Avatar
I am under the same impression. The install should be exactly the same too so check out the install threads for the step rail. Drilling will be required.
gundad likes this.
RojStock is offline
post #5 of 8 (permalink) Old 09-03-2014, 01:36 PM Thread Starter
gundad's Avatar
Thanks guys. I didn't understand their definition of bolt-on. I assumed that meant you needed some of their bolts and the holes came provided by the nice folks at the jeep factory.
gundad is offline
post #6 of 8 (permalink) Old 09-03-2014, 02:14 PM
FuryIII's Avatar
Generally "bolt on" means the vehicle has existing attach points you will use. You could have to loosen an existing bolt, share a bolt, bolt on a bracket, etc, but shouldn't have to cut a new hole in the metal, or weld anything on.
The RRO sliders/steps use existing holes under the factory trim you remove. With the mopar sliders you have drill the holes larger, don't know (yet) if that is the case with the RRO ones.
I have rock slider steps ordered and I'm waiting for delivery.
2014 Jeep Cherokee Trailhawk
Granite Exterior - Black Interior
Cold Weather - Tech - Comfort/Convenience
Tow - Leather - Sunroof - Hood Decal
8.4AN - 9 Speakers
Chrysler Lifetime Maximum Care
Build: 05/17 Hr 13
FuryIII is offline
post #7 of 8 (permalink) Old 09-03-2014, 02:36 PM
RojStock's Avatar
The usual "Bolt-on" definition does not apply to RRO rails. You will be drilling and then eventually, once all your drilling is done, you can bolt it on.
6 holes under the existing trim need to be enlarged and 8 new holes will need to be drilled into the pinch weld underneath. Definitely check-out the install thread(s) on this forum and it will make things way easier for you.
clew, zzjdzz and FuryIII like this.
RojStock is offline
post #8 of 8 (permalink) Old 09-03-2014, 04:31 PM
clew's Avatar
And just to add...the 8x2 new holes that are to be drilled can be a beast
RojStock, zzjdzz, eak and 1 others like this.
clew is offline
RRO Roof rails, or wrong rails? Spidaur Exterior 3 06-13-2016 09:16 PM
Rocky Road Super Slider Rock Rail install Trailhawk84 Exterior 312 11-22-2015 11:42 PM
RRO Roof Rails and Adventure Rack are on Hudsonhawk Owners' Garage 64 05-17-2015 10:17 PM
RRO Roof Rails w/ Yakima Megawarrior gundad Owners' Garage 15 07-16-2014 12:33 PM
RRO roof rails and adventure rack Hudsonhawk Exterior 9 05-22-2014 04:36 PM
