Increasing Approach Angle - 2014+ Jeep Cherokee Forums
post #1 of 2 (permalink) Old 09-09-2014, 11:02 PM Thread Starter
Does anyone know if you can replace just bottom fascia on a latitude with the th fasciato get more approach? I have the adII so with the oem tires the approach should be similar. Thanks in advance.
tytlynz is offline
post #2 of 2 (permalink) Old 09-11-2014, 07:45 AM
If you look at the TH side by side with the others, you will see the entire front bumper cover assembly is different. It is not just the bottom fascia. I think you would have to replace the bumper cover and the the small plastic panels in front of each wheel as well.
John
Hudsonhawk is offline
Headrest Angle? samsled Interior 49 11-04-2015 12:15 PM
