Rear Cargo Carpet (Quick DIY Project) - 2014+ Jeep Cherokee Forums
 10Likes
post #1 of 17 (permalink) Old 04-10-2015, 01:25 AM Thread Starter
homac's Avatar
I have done this in a previous Jeep and my Golf Wagon. It takes roughly 15 minutes, looks professional, and makes access to the spare tire area easy:
  • Go to your local hardware store and look for a black "Utility Mat" with rubberized backing.
  • Find one that is 4'x3' or larger (i.e. 4'x4' or 4'x6')
  • You want the rubberized backing to protect against spills should you end up carrying something wet.
  • Look for Black with lighter flecks, these seem pretty standard and somewhat easy to find (it also perfectly matches the interior). I have seen them for between $15-$20, cheaper if your lucky.
  • Once at home flip the mat rubber side up and mark it to the dimensions shown below. (see picture) The fewer cuts the better, consider using a straight edge like a metal ruler if you have one available.
  • Using a good pair of scissors or alternatively a utility knife cut to size.
  • The most challenging cut is the slightly rounded edge, however cut it larger, then trim after test fitting a couple times in your cargo area if you are worried.
The nice thing about these is they allow easy cleaning (remove and shake off), you can even hose them down if something really crazy happens. You can also lift them and quickly gain access to the spare tire area (some folks use that to store odds/ends).
2015 Jeep Cherokee (Trailhawk)
2010 Golf Variant
homac is offline
post #2 of 17 (permalink) Old 04-10-2015, 07:06 AM
Great idea! Thanks for posting the dimensions too! Looks good and tough too.
post #3 of 17 (permalink) Old 04-10-2015, 03:01 PM
post #4 of 17 (permalink) Old 04-10-2015, 03:15 PM Thread Starter
homac's Avatar
Yes, that is almost exactly what I used. You can trim off the rubber boarder and then trim to size.
2010 Golf Variant
homac is offline
post #5 of 17 (permalink) Old 04-15-2015, 11:03 AM
I picked up the mat at Lowes, was $16 and change with taxes added. It's exactly as I expected it to be. The weather was a bit icky and I didn't feel like screwing with it, so I tossed it on the hardwood next to an area rug just to have it "out of the way."
Turns out my girlfriends cat's love it. They basically sit on that 4x3' mat and roll and play and sleep. Who knew? Lol.
May have to get a new mat for the TH.
007 likes this.
post #6 of 17 (permalink) Old 04-23-2015, 02:10 PM
I did this project last night. Cut to fit and works like a charm! Thanks for the idea!
Granite57 is offline
post #7 of 17 (permalink) Old 04-23-2015, 03:03 PM
You can do the same with a $9.88 rubber mat from Home Depot
http://www.homedepot.com/p/HDX-31-75...27R1/203643165
bundu is offline
post #8 of 17 (permalink) Old 04-23-2015, 05:07 PM Thread Starter
homac's Avatar
Glad it worked ! I took the measurements and thought I should share for us DIY'ers.
2010 Golf Variant
homac is offline
post #9 of 17 (permalink) Old 04-24-2015, 04:38 AM
Nice project!
2001 Jeep Cherokee Sport
roadwanderer is offline
post #10 of 17 (permalink) Old 05-10-2015, 09:06 PM
Did this for the back of my KL today and it fits & looks perfect. Thanks for the idea!
2015 Limited 4x4 | 3.2 V6 | Deep Cherry Red | Luxury Group | 8.4AN | Panoramic Sunroof
TheManKev is offline
Rear Cargo Carpet Mat Robster 2014+ Jeep Cherokee General Discussion 23 10-02-2015 10:17 AM
Rear Cargo mat/tray question jsf721 Interior 4 03-21-2015 11:18 PM
FS: Rear Cargo Cover dawhitesTH Cherokee (KL) Parts & Accessories 11 09-12-2014 10:49 AM
Rear cargo mat Ajalfano Interior 19 04-09-2014 02:31 AM
Hook for the rear cargo cover sfdxsm Interior 3 01-09-2014 01:41 PM
